Question about Gaggia Titanium Espresso Machine
Coffee does not dispense to cup catch
When I make my coffee selection, the coffee beans are ground and pressed and the water activates, however the water is dispensed via the steam nozzle and not to the coffee catch cup, plus it totally bypasses the coffee grounds so the catch tray is full of plain water, not coffee so it's not as simple as just placing my cup under the steam valve in addition my steam nozzle is in the closed position.
4 Suggested Answers
  • 1089 Answers
SOURCE: Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Posted on Jun 17, 2009
SOURCE: ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
Posted on Jul 31, 2010
z34aga
  • 137 Answers
SOURCE: I have a gaggia deluxe coffee machine which won't
it can be 3 problems, you can eliminate them 1 by 1 in this order:
  1. Calcium in the boiler > you unscrew the filter&filter holder(2 bolts) than you unscrew the screw in center (you see it after disassembling filter holder). If it is full with calcium, the pipe which goes vertically up for few centimeters you can drill it with 3 mm drill BUT AFTER YOU TAKE OF THE FINAL 4TH BOLT. You continue and release the short pipe and provide flow from boiler, test it and clean it than with decalcifications'(it will be more easy for you)
  2. We suppose case 1 isn't, and u have flow after unscrewing the 4TH bolt, than you must check the pressure valve (it returns the higher pressure with dispensing water back to container. Follow the short rubber pipe and you will find it. check the gasket and functioning of it
  3. Pump could be to week with pressure that she can't open the spring of valve above 4TH bolt, in this case you need to change pump.
Posted on Mar 02, 2011
Grinder spins. Hopper is full of beans. Why is no ground coffee dispensed?
You will probably find that the grinder is bunged up with grounds. This can happen if there is a bit too much steam inside the housings. The grounds bind together and will not drop with gravity. Pull the grinder apart, clean it out then run it with the top housing off and see if you can observe any leaks/steam. There will be some steam, you are looking for excessive steam.
Sep 13, 2015 | Miele CM 5200 Espresso Machine Black
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
Slow water dispensing
How slowly in comparison to other units? Have you measured it how fast it runs ?? If slower than when Syntia was brand new is maybe caused by an insufficiently cleaned brew group or lack of proper descaling .Calcium or mineral in the unit's lines and boiler can slow down your machine .
if the filter screen is partially blocked from old coffee tar then water cannot flow faster . In my opinion it always runs slowly when rinsing .
If you use a "Coffee Residue cleaner "only use it in the pre-ground
setting chute and use only a pinch at a time . then run pre-ground setting without any grounds and run another one to clear the detergent
Very oily ,sticky coffee beans can plug up any late model superautomatic's system as you can read in the unit manuals . Because the laser cut holes in the fliter screen are so small that any coffee tar will not flow properly through the screens .I have had many machines which had to be switched to a less oily bean to work more than for2 or 3 cups .When beans are roasted too fast and too hot ,the coffee oil can turn to coffee tar .
My Xelsis unit cannot handle very oily beans . 2 cups and it STOPS
I only use beans roasted to American Coffee institute recommended procedures .
Aug 30, 2014 | Saeco Syntia Espresso Machine & Coffee...
Miele coffee maker water not coming through to brew unit
try cleaning the nozzles using fine wires or tobacco pipe cleaner kit. it look like you have a blockage on your tubing leading to nozzles.
Nov 06, 2013 | Miele Coffee Makers & Espresso Machines
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
Gaggia Titanium - I had a mesasge come up saying that the Grinder was blocked. I cleaned the doser channel by removing the coffee doser and then the coffee dispenser. I then opened the small spring loaded...
Hello there,
What you need to do is to first prime the machine then you descale it after doing this the machine will work perfectly fine.
To descale the machine, please click on the link below so as to get the manual and know how to descale it as the descale procedures and priming procedures are in it.http://www.espressotec.com/store/pc/catalog/gaggia/ga1150_gaggia_titanium_manual.pdf
Hope this helped.All the bestElect_Comp
Oct 08, 2011 | Gaggia Titanium Espresso Machine
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
Feb 10, 2011 | Coffee Makers & Espresso Machines
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
For the steam check the end of the nozzle to make sure it is not blocked.
For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
65 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
