Question about Kenmore 64852 Electric Dryer
Need to change the belt
I have a kenmore 80 series dryer. Model 110.76862501. We think the belt is broken. We removed the back panel but cannot figure out how to remove the rest to get to the belt. Can you help? Thanks a bunch!!!
    President:
  • 1,136 Answers
Hi, You need to remove the two screws at the lint screen. Then use a flat blade srew driver and insert it in the gap between the top and the front panel. Pry the top upward.
Locate the screws inside the front panel in the upper corners. After these have been removed, the front panel will come off lifting it up.
Now you can see the tub and the belt. If you have the wrapper the belt came in, you should be able to string the new belt. I hope this helps. If I can assist you mmore, please let me know.
Thanks
Vic
Posted on May 21, 2009
  • Kenmore Master
  • 2,005 Answers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
How do I replace a dryer belt on Kenmore dryer
You have to practically completely disassemble the dryer and remove the drum. If you can't figure it out, you should call an expert. Sometimes getting it apart isn't bad, it's putting it all back together that gets you. ;-)
Dec 27, 2009 | Kenmore Dryers
Ho do i access the belt on the kenmore 60 series dryer ? therers a 1/4 panel at the bottom . I think my belt is broken
take out phillips screw by lint screen. pull top panel towards you, lift top. remove two 5/16 inch screws on inside of front panel. undo door switch plug on right side at top of inside panel. pull panel up and remove. to remove belt push tension pulley to right and pull belt off. reverse to put back together
Jun 21, 2009 | Kenmore 60172 Electric Commercial Dryer
Removing the back of the dryer
to get at belt you will need to get true the front of dryer.When you have top up there should be 2 screws on both inside corners on front panel remove them and lift up and towards you the front panel should come off.After that look under drum .Sounds like your belt sliped off the idler pully you can then put belt back on and reverse the steps.If any more help needed feel free to ask hope i fixya:)
May 21, 2009 | Kenmore 64852 Electric Dryer
Broken door switch
on the corners of unit console ,,are plastic end caps,,pull them of with your hand ,,grasp it and tug hard,,now you see 2 a scew under each cap..remove screws ,,than flip the console back...now under the console theres three screws holding lid dowb,,remove them slide lid forward ,,,but screw for door switch are on the bottom of front door panel..always unplug first...onthejob
Jan 15, 2009 | Kenmore 63942 Dryer
The drum of my Kenmore 80 series electric dryer is not turning
sounds like you need a new drum belt. start by taking the top off then the front panel will have screws inside for removing the front. then once the front is off you will see the motor and where the belt should be. if the belt is broken, replace it, if not just put it back on the motor and idler pulley.
Dec 28, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Open Questions:
My Kenmore 80 series dryer (64852) develops a buzzing sound while drying. Functionally it works just fine. However, after about 20min (this varies) of run time the dryer will usually begin to buzz. The buzzing seems to come and go for a short while and then becomes more constant. Then about 10min (give or take) before the dryer shuts off, the buzzing usually stops. It doesn't seem to matter what setting the dryer in on. (e.g. "Timed Dry", "Automatic Moisture Sensing") Often times when the dryer begins buzzing I can turn the dial back a bit and the buzzing usually stop for a short time. But it seems to pick up with the buzzing again before the dial reaches the same point where it began the first time. Also, because the buzzing remains fairly constant, and I get the impression that the thermostat is cycling things off and on like it should, I don't really think that this is an issue related to the heating element. Although I've been known to be wrong before. As far as I can tell it does have something to do with heat though, because the buzzing only seems to start after the machine has had time to run and warm up for a while and then stops during the last 10min when I assume the machine would be cooling down. Also, I keep the "End of Cycle Signal" in the OFF position all the time. When I have turned it on in the past it sounds distinctly different from the noise it make while drying. One more thing. The buzzing doesn't sound like vibrating parts to me. Thanks for any help you can give.
Oct 30, 2010 | Kenmore 64852 Electric Dryer
Kenmore 64852 Electric Dryer Logo
603 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
