Question about GSI Coffee Makers & Espresso Machines
Water/coffee does not come out of GSI stovetop espresso
Some water/coffee will come out, but then all i get is steam; it worked once after putting in a new gasket
  • 2039 Answers
SOURCE: Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
SOURCE: Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: Where to buy replacement gasket
go to www.vev-vigano.com or www.fantes.com
Posted on Mar 12, 2009
SOURCE: General question about the Mr. Coffee Espresso ECM10
http://safemanuals.com/user-guide-instructions-owner-manual/MR%20COFFEE/ECM10
Posted on Mar 31, 2009
z34aga
  • 137 Answers
SOURCE: Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Posted on Apr 02, 2009
Only little coffee is coming up
Although the gasket looked fine, once replaced the coffee pot functioned correctly.
Mar 30, 2014 | Bialetti Cooking.com Stovetop Espresso...
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Have a Salton EX 15 coffee Espresso maker and my espresso top dial (strength control) is now clicking versus smoothly turning and no water is now coming out. The froth stem is working fine. Also cant find...
The reason why the setting dial is clicking, because it's stuck on steam only and when you turn the dial to make the coffee it's grinding instead of turning smoothly. you need to remove full top cover. And to do so, you need to remove the two screws hidden under plastic caps next to opening where you add water for espresso or steam. Once the screws are out you can lift the top of slowly unlocking the corners.Tthe dialer knob stay on the top cover. Using a basic plier or locking plier turn the nozzle stem to unlock it from steam position...When you put it back together make sure it's back on steam not so tight and put cover and dialer setting at steam. put back the two screws and covers...Enjoy... from : jenlwe.thecustomeradvantage.com
Jan 05, 2011 | Coffee Makers & Espresso Machines
Gaggia won't prime
Put a cup under the steam wand and then open the steam valve while turning the pump on. Once you have pumped a few ounces of water out of the steam wand you can close the valve and it will start pushing water through the grouphead.
Michael Ventura Laguna Beach
Oct 11, 2009 | Gaggia Classic Espresso Machine
Greetings!
Put desired amount of water in resevoir (plus a little extra to be used to steam your milk for latte) and close up tightly.
Put espresso grind coffee in basket and tamp down with a tamper. If grounds are not packed, steam will seep through and will cause an erosion of sorts instead of just letting the steam hit the grounds.
Put the basket with handle group in recess rotating to the right as far as it will go.
Rotate the ON/OFF switch to the symbol for "Brew" until you get out the desired amount of espresso.
Then, take a caraf of milk and immerse it with the plastic black steam arm. Rotate switch to "STEAM" and froth milk. In the beginning, ensure that you have enough water for the espresso AND enough left to froth without having to shut off machine, refill with water, just to froth.
Be careful when you open the water resevoir cap after brewing because there is a vaccuum created and a burst of steam will shoot out the lid and may burn you.
The gasket above the grounds hopper eventually will deteriorate and more steam will escape than espresso is produced. There is no replacement parts for this machine since it was made in China according to a Mr. Coffee representative that I called this morning at 1-800-MR-COFFEE (800) 672-6333.
Good luck with your machine. Hope this helps! If you don't have a tamper for the grounds, I found one at Bed Bath and Beyond. It is stainless steel with 2 sizes. The smaller size works for this model.
Jan 17, 2009 | Coffee Makers & Espresso Machines
My Vev Vigano Kontessa 12 cup espresso maker does not work properly
I had the same problem, so I embarked on a search mission. Here's what I found, and it worked for me. First, these pots are designed to work only for the amount of water specified for each size. So I have a 6 cup pot that requires 9 oz of water. If I try to put 8 oz. of water, I only get about 1 maybe 2 oz of coffee. Size of the grind doesn't matter as long as you stick to espresso grind (some coffee grinders have several settings for espresso grind). As soon as I put exact amount of water, it works much better. Now, you have to understand that some water gets evaporated as steam, and some water should remain in the boiler section of the pot for safety reason. The general advice is to take the pot off the burner as soon as the gurgling sound reaches its peak and just starts to subside.
That may result (as least for me) in weaker coffee than I like. So what I do, is I fill the coffee funnel with coffee grinds, tamp it very lightly, and then using a wooden skewer I make 3 or 4 holes all the way to the bottom of the funnel. That will help the steam to escape. Before I learned this trick, I thought it was a valve problem or a seal problem. As soon as I tried this trick, bingo! I personally like strong coffee. So I didn't want to compromise it and start adding less coffee to the funnel. The thing is that steam wets and expands coffee grinds, and that may be enough to hinder the process. If you make several holes, steam will not be building in the boiler section and escaping thrgough the valve or break the seal on the gasket.
Hope this helps.
Apr 11, 2008 | Vev Vigano Kontessa Oro 12-Cup Espresso...
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Coffee Makers & Espresso Machines Logo
11 people viewed this question
Top GSI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a GSI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
