Question about Whirlpool GH5184XPQ Microwave Oven
Fan runs intermittently food smokes - Whirlpool GH5184XPQ Microwave Oven
Food fire food overcooked and smoked in microwave bad odor and now the food is gone but the smoke odor is left. how do I get rid of the smell now. microwave itself is unharmed thank you, hank
You should be able to get a cleaner spray suitable for use in microwaves. Give the insides a good spray and a good clean, it should take it away. Make certain there is no burnt deposits anywhere.
Apr 27, 2017 | In Microwave Ovens
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
Intermittent heating
From the description you have a bad latch switch on the door caused by build up of food particles or ware.
Mar 05, 2012 | Bosch HMV9305 Microwave Oven
I placed food in the microwave over to heat for 19 seconds, when it was finished I smelled smoke coming from the oven. The food was fine. I unpluged the oven. I tried it a couple of days later, it...
the smoke probably came from the heated food. try using it next time with different kind of foods and also try it to the same kind of food that produces smoke but observe carefully what will happen.
Dec 29, 2010 | Emerson Microwave Ovens
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
(1) Loose hinge (2) No longer heating food (3) Electrical smoke when microwave is ON
To add to my previous clarification request, the smell may be coming from the magnetron. It will overheat if the cooling fan is not running.
But again, I likely covered it in my previous Clarification Request, but if you still want help, Please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 16, 2008 | Magic Chef Microwave Ovens
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Mar 05, 2008 | GE JVM2050 Microwave Oven
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
14 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
