Question about Whirlpool WED5500S Electric Dryer
Dwjr ele 2406026 fm54
No heat
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The stock number is IED4400SQ0 The
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 19, 2011
emissionwiz
  • 76649 Answers
SOURCE: motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Posted on Jan 19, 2012
Testimonial: "Thanks, Dennis solved the problem, now the dryer is super hot any suggestions?"
appliance765
  • 83 Answers
SOURCE: dwjr-ele-2406026-fm54
Hay Kirk , most likely your door switch needs to be replaced if that doesn't help test all three fuses for continuity . good luck APPLIANCES R EN
Posted on Mar 03, 2013
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
I just bought an older whirlpool dyer (MOD wed5300sq0 type dwjr-ele-2406026-fm54) and it spins counterclockwise. Is that an issue? The heat is blowing out of the house in the correct direction but I didn't...
The drum on the dryer is powered by an ac motor. You cannot change its direction of rotation by changing lead connections. AC has no positive or negative leads. It must be OK as is
Oct 29, 2014 | Dryers
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me melissamaemartin@yahoo.com I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
Dwjr-ele-2406026-fm54
Mar 02, 2013 | Whirlpool Inglis IP8200 Dryer
Motor wouldn't start replaced the motor and it still won't start?
Jan 19, 2012 | Whirlpool Dryers
I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
The stock number is IED4400SQ0 The type is DWJR-ELE-2406026-FM54 The problem is that my dryer isn't working. I've checked all of the electrical wiring and they're properly working fine....
heatman101
Jun 16, 2011 | Whirlpool GEQ8858H Dryer
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
Whirlpool WED5500S Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
