Question about Hayward Power Flo Lx 1 1/2 Hp
Not getting full power
Checked power outlet it find power is very low both speeds then dies in asecond...
  • 59 Answers
Usually indicates low voltage. get a volt meter and measure voltage.
David
Posted on May 25, 2009
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
Why does my cherokee turn off while driving.Then i restart it and it runs.ALSO the motor shakes and loses power and turns off.
I would test coil and ignition module. Module has a low speed and a high speed section, so high speed part could be bad and cause unit to die, then start right back up on low speed part.
Jun 10, 2015 | 2000 Jeep Grand Cherokee Laredo
The dryer fails to dry unless it is run for asecond cycle 2which would be usung substantial power
I assume this is an electric dryer. First, make sure you have a clear airflow path. Lint screens are not perfect, and some dryers are very prone to packing stray lint in the ductwork, especially where there are turns or changes in cross-section shape. Be sure to also check the outside vent to make sure it is not clogged.
If you have good airflow and still have problems with slow drying, check for heat. Try running one load on low heat, and another on medium heat. If on one of the cycles, the dryer never gets warm, you have a burned-out heater element. If it never gets warm, you should check for an open thermostat first, then the heaters. (High heat uses both the medium and low heaters, so you don't have to check high heat separately.)
I can't tell you what the capacity of your dryer is without the make and model (you can probably get the specifications from the manufacturer's website or user's manual). Usually, it is one full washing machine load, if the washing machine is loaded properly and the laundry is not packed in.
Oct 06, 2014 | Dryers
2005 Audi A6 4.2 with heavy steering
Check the power steering fluid, it could be that it's just low. If it's full it might be time to get it changed. Also check the tension on the motor belt. If it's loose you won't get full power to the pump.
Jan 08, 2013 | Audi A6 Cars & Trucks
My 26HT reconditioned trimmer will start and run on full choke but, if I take it off to middle choke, it dies. It doesn't run right on full choke but does rev up enough to engage the blades. Has...
sounds like a carb problem You will have to take the carb off and strip it down to parts clean out all the ports with a good cleaner I use brake clean reassemble and reset the High speed and low speed jets at 1.5 turns out then adjust from there
Jun 14, 2011 | Homelite Factory Reconditioned 26cc...
Are they reliable iam thinking of buying asecond hand one
hi,
buying a secondhand bike is a good option according to me,BUT the most important thing is to make the bike checked with a good mechanic regarding the important parts of the bike.
1-pistion
2-timing chain
3-valves(inlet and outlet)
4-cylinder
check all of them before buying if they are ok then only buy otherwise dont.
cheers
Jul 29, 2009 | 2008 Victory Vegas 8-Ball
Hayward Power Flo Lx 1 1/2 Hp Logo
74 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
