Question about Car Audio & Video
Pioneer deh 2600ui
I have fitted the car stereo usind the wire harness supplied also fitted a subwoofer built in amp too. Problem is when my ignition is offthe settings did not save .. Please help ps fitted to a vauxhall vectra b
5 Suggested Answers
  • 6 Answers
SOURCE: i bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Posted on Nov 13, 2008
ltfrc
  • 227 Answers
SOURCE: wiring problem for DEH 1430R
I have to ask if you are willing to spend a little time with the 30 wire bundle? First of all you have to have a 12volt dc tester and a 9v dc battery. Take the tester and check each wire of the 30 wire bundle until you find one with 12 volt. Mark it and set aside. If you get more than one with voltage that is OK just mark them w/tape and make sure they get capped or taped as not to short anywhere. Now that you know which wires are HOT, lets move onto the others.If possible find out how many speakers are in the vehicle. Take the 9v battery and find small gauge wires in the bundle of 30 remove insullation on the wires about 1/2 inch touch one wire to one post on the battery and another to the other post (Just a tap, do not hold on too long) you will hear a speaker pop. Find out which it is front left, back right etc. and mark the pairs that make it pop. If possible to pull the speaker you can identify the wire colors from the speaker to see if they are in fact in the 30 wire bundle. After you locate your power and speakers the 15 wire harness should be easy to attach to the proper connections. Hope this gets you going.
Posted on Jan 04, 2009
  • 18 Answers
SOURCE: Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Posted on May 27, 2009
  • 773 Answers
SOURCE: PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Posted on Dec 15, 2009
How do i install a pioneer deh-1550 car radio
The installation manual is here
Pioneer DEH 1550 Installation Manual
PIONEER DEH-1550 INSTALLATION MANUAL Pdf Download.
https://www.manualslib.com > ... > Car Stereo System > DEH-1550 XU
View and Download Pioneer DEH-1550 installation manual online. DEH-1550; DEH-1550B. DEH-1550 Car Stereo System pdf manual download. Also for: Deh-1550b, Deh-3450, Deh-2450f.
[PDF]DEH-1550UB DEH-1550UBG - Pioneer
www.pioneer-latin.com/.../operating%20manual%20(deh-1550ub)-eng-esp-por.pdf ???? ???????? CD ?? ????? RDS. ?????? ?????? CD RDS. Espa?ol. DEH-1550UB. DEH-1550UBG. Portugues (B). Owner's Manual. Manual de instrucciones i ... PIONEER Service Station. Press to recall preset stations. Press to select the next/pre- vious folder. AUX input jack. (3.5 mm stereo jack). 6 Disc loading slot 3. O USB ...
How To - Understanding Pioneer Wire Harness Color Codes for DEH ...
? 6:05
https://www.youtube.com/watch?v=kR2MO2kwFug Nov 14, 2016 - Uploaded by pioneerelectronics
Learn about the Wire Harness Color Codes for Pioneer in dash receivers that do not have video screens. DEH ...
How to restore and reset your Pioneer DEH radio - YouTube
? 1:20
https://www.youtube.com/watch?v=_QyuVanWfLA Jul 26, 2016 - Uploaded by Five Star Car Stereo
in this video we show you how to restore your radio into factory default settings. ... to restore and reset your ...
Mar 24, 2018 | Pioneer Car Audio & Video
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
Feb 28, 2011 | Pioneer Car Audio & Video
I need a wiring diagram for a pioneer deh-p6400.. please help..
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
I just hooked up a pioneer deh-5100ub stereo in my 2004 dodge ram 1500 pick-up using a store bought wiring harness but I cannot get any sound from my speakers now.
Does you truck say Infinity anywhere on a door panel or such? If so you need to make sure that the blue wire from the store bought wiring harness is connected to the amp turn on from the pioneer.
Mar 02, 2010 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Installing A pioneer stereo Model DEH SP091 in to a chrysler sibering. Wiring on car is different the Pioneer stereo
you need a model specific wiring harness available at your local auto parts store, best buy, circuit city, etc...
Nov 30, 2008 | Car Audio & Video
Dont know how to insall it !!!
Purchase the aftermarket wire harness at from a local installation shop. WIres will match color for color to this harness then mate to the factory connector. This could save hours attempting to figure out the factory wire harness.
Nov 11, 2008 | Pioneer DEH-2800MP CD Player
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
