Question about Panasonic PanaFax UF-8000 Laser Fax
The paper tray will not close. - Panasonic PanaFax UF-8000 Laser Fax
    President:
  • 3,085 Answers
Remove the paper cassette and reform the metal plate at the bottom of the machine. This may take many tries.
The two plastic buttons on the paper tray must slip into the cutouts on the metal plate. Also make sure your machine in not too close to the wall.
it sounds dumb, but i've seen this.
Posted on Jun 04, 2009
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Thanks,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | Brother MFC Office Equipment & Supplies
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
HP 2200D Amber light keeps flashing! ..and nothing else
Following are the reasons and its solution for amber light keeps flashing:
1. Toner have been empty.
Sol : Refill you toner.
2. Printer's paper tray do not close properly or paper in not in the tray.
Sol : Close the paper tray properly and keep some papers in the tray.
3. Any door of printer is open or not properly close.
Sol. : Check all the doors that is close properly or not.
If problem is still remaining then contact a professional to repair this printer.
Regards
Ashly
Feb 25, 2010 | HP LaserJet 2200D Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
C0920
Paper Tray Lift error code. Check and reload all the paper in all the trays. Power off then on to reset. If this does not solve the code then pull out all paper trays. Reset machine leaving alll trays OPEN. Close the trays 1 at a time waiting 30 seconds between each tray closing. If the code comes back after closing a tray then that will tell you which tray has the problem. You can leave that tray open so you can use the machine and also you can check that tray more closely.
Oct 21, 2009 | Minolta Di3510f Bizhub Copier
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Panasonic PanaFax UF-8000 Laser Fax Logo
41 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
