Question about ASUS P5S800-VM Motherboard
Asus p5s800-vm MB has complete power lets monitor know
But has know display period. its as if the cpu fryed but if thats the case the MB speaker would go off. cpu fan works, graphics card fan works ya hear cd dvd doing test at start HDD work ya even see HDD flashing LED work but still no response. tryed resetting the bios and run off the internal card. same result nothing power goes everywhere but no display to monitor. even tryed graphics card from this pc. nothing.
Any sugesstions.
  • 3 more comments
  • Anonymous May 21, 2009
    nope not booting up single seems to be sent to the monitor the relay starts but it flashy up monitor working please check signal cable keyboard lights do not flash either only thing is all fans come on and the HDD light is a single flash every 10 secs ya think possiable cpu gone kaputt im not sure
    does not have a 3.5 inch installed replaced that with a media card reader. i will try monitor 2 on this pc see if it starts to confirm whether its the monitor of the pc. however if the motherboard indicartor light is on the MB aint fryed its summat else. ok confirmed not the monitor swapped VGA cables ovver and pc1 monitor starts and displays pc 2 visual 100%. any other ideas
    taken ur advice down the the bare min only thing plugged in is hdd cd/rom memory cpu nothing else even reset bios so it looks for internal graphics card.. Nothing same result. prob is these days ya looking from 55 pounds to 500 pounds just for a new motherbaord thats before memory, grapahics and the cpu. pc1 is my primary to add to it replaced PSU with existing 155 watt unit with a 300 watt worked fine for 2 weeks bit of growling going on but then last night on first post powers up everything but the cpu. is it possiable increasing the psu to 300 watts casue of the graphics card nvidia 7600 GS req min of 150 watts to run. drained the rest of the system. well tis runs a lot cooler or did.
    Does this mean a whole new motherbaord and cpu pref old school so i dont have to replce the memory or grapics card. lets us know. ty..
  • ikkenom May 11, 2010
    Disconnect the power to the CD-ROM and to the hard-drive.
    Insert a diskette into the 3.5" drive, and reboot the computer.
    Does it try to spin the diskette, i.e., trying to boot from it?
    If not, your motherboard has a problem.
    If you connect your monitor to the VGA-output from a friend's laptop, does your monitor work correctly?
    Have you tried a different power-supply?
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    All indications you offer say that this Mobo is booting up. If the keyboard num lock and caps lock led's respond it is definitely running processes. Are you sure it's not the monitor at fault?
    Problem Solver:
  • 9 Answers
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
Posted on May 21, 2009
PC Not Displaying anything on Powerup
check the cpu and try other memory modules or if you have more then one try them one at a time. try also reset the motherboard
May 28, 2010 | ASUS P5S800-VM Motherboard
My monitor won't open and i can't turn off my cpu everytime i'm pressing the power switch, it never turn off
Try this, remove battery of motherboard , wait for about few seconds and put it back in ( that will reset bios to default) in most cases this worked. Try and let me know.
Mar 25, 2009 | ASUS P5S800-VM Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
BIOS-Typ: AMI
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
ASUS COMPUTER PROBLEM
Hello owners of the Asus P5S800-VM motherboard. This Asus board uses an integrated PCI graphics card. (That means it’s built into the board, you can not see it. Its part of the north bridge SiS661FX chipset). Everyone will need their manual so you can follow my instructions. If you no longer have your manual, please click on the ASUS P5S800-VM link below. A pop-up windows will open & you will need to choose the operating system from the dropdown menu. Than click Search.
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
This downloadable manual can only be read with Adobe reader software. If you need Adobe's software, you can download it from Adobe at this next link: http://www.adobe.com/products/reader/
Shut down your systems; unplug the power cord from the PC's power supply. Open your case.
Please remove the AGP video card from the board; if any have one has one installed. (If you do not you will not receive display on your monitor. Once removed you now need to clear the bios/cmos.
On the board find the cmos/bios jumper as shown on page 1-21. Move the jumper to cover pins 2 & 3, count to 15 & move the jumper back to pins 1 & 2. One this is done. Close your case. Plug the power cord back into the power supply. Now we need to enter into the bios. Boot your PC & press the Delete key on your keyboard every 2 seconds. The bios main menu will open. Read the instructions at the bottom of the menu. This will show you how to move about while in the bios using your keyboard. (Can not use the mouse in here). Go to the title Advanced. Open "Chipset" page
2-17. See manual section 2.4.3 page 2-20. Change Primary Graphics Adapter to [AGP]
Save the bios & exit it. The system will auto restart. Press & hold the case power on /off button until the system shuts off. Unplug the power cord from the power supply. Open your case. Insert your AGP card. Make sure it is seated evenly & fully. Re-check all power connections & data connections before closing the case. Re-connect the power cord to the power supply. Boot your PC. You should have display. Install your graphics cards software. Check windows for any updates.
Life should be good. The ASUS P5S800-VM can only use a 1.5volt AGP card & nothing else. Check the manual for your AGP card & make sure it is 1.5v compatible. If its voltage is higher you will not receive display. This next link will show what a 1.5v graphics card looks like. Notice the copper contacts & its separation. Turn to manual page 1-20 for another 1.5v card with more than two separations.
Good luck everyone!
Please vote.......
Mike
Sep 13, 2008 | ASUS P5S800-VM Motherboard
P5s800
The fact is because the motherboard's Video Card Has BEEN overheated. You may need to buy a new video card
Aug 17, 2008 | ASUS P5S800-VM Motherboard
HI can any body help me
Audio Driver Here :
ftp://152.104.238.19/pc/audio/6251_Vista_APO.zip
Raid Driver Here :
http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5S800-VM/SiS_RAID_64(WHQL).zip
Network Adapter :
http://file.abit.com.tw/pub/download//driver2/realtek_lan/100/v6101.zip
Dec 28, 2007 | ASUS P5S800-VM Motherboard
I have Asus P5S800 main board
dr-afacan, You unfortunatley are not giving me a lot of info to work with. There could be several things to try. First check your cases front panel to Board connections. Then if they are correct I would swap out the power supply with anything compatible to check and see. If that PS is really OK. If you do not have the info for the board go here http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e1767_p5s800-vm.pdf
Next step would be to either check the processor, possible BIOS settings or update. Or you unfortunatley just have a dead board. Asus has a good customer RMA system... Just some thoughts.....PCdok
Oct 14, 2007 | ASUS P5S800-VM Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
CHASSIS INTRUDED
You BIOS settings have been reset and you need to set it up again. Chassis intrusion needs to be turned off. You can download the user setup manual here: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e2419_p5s800-vm.pdf BIOS setup is in Chapter 2. There are alot of settings and it goes into detail on how to set them. This is truly an Awesome motherboard! I wish mine was like this. Follow the setup carefully and you can't go wrong.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard Logo
239 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
