Question about Samsung RF4287HARS French Door Refrigerator
How to change the temperature on a samsung refrigerator RF4287
2 Suggested Answers
  • 310 Answers
SOURCE: Water is coming under freezer section of Samsung RF4287 bottom freezer French Door
You have a plugged evaporator (cooling coil) drain pan opening or drain line.
Posted on Feb 06, 2015
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrigerator freezer model RF4287 has OF codes showing on both freezer and refrigerator. Cannot reset by unplugging for 3 seconds or pressing codes for three seconds. How can this be fixed
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Ok, on the left hand side of your refrigerator display board there are two selector buttons. Press on both at the same time for 3 seconds. This will take you out of the OF mode.
Apr 19, 2015 | Samsung Refrigerators
Feb 06, 2015 | Samsung RF4287HA
Refrigerar wont cool down
Sounds like you have a problem with the defrost coil and temperature sensor. Samsung coils are famous for failing and causing temperature problems. Best suggestion is to Google something like "Samsung model ..... coil repair" this should give you some guidance.
You can also check YouTube - have a look here for some guidance -https://www.youtube.com/watch?v=DO2wDd16OkA
Its not your model but will give you an idea what needs doing.
Good Luck and I hope this is of some help.
Sep 29, 2014 | Samsung Refrigerators
My samsung RF4287 (french fridge doors and freezer on the bottom) will not freeze.
check if there is build up of snow in the freezer behind the cover.
possible defrost problem
May 14, 2014 | Samsung Refrigerators
We cannot change the temperature of the freezer. Everything,even the water to the ice machine is so frozen (8*) that we cannot get ice. How do we change the temperature
I am not sure what model you have, but on my RF265AABP there are two buttons and digital displays at the top of the refrigerator, visible when the doors are open. One sets freezer temperature, the other refrigerator temperature. On my model if they read 88 88 with a blinking digit, it indicates a broken wire to a temperature sensor, usually the ice maker sensor since it tends to get snagged and damaged easily.
Apr 04, 2013 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung refrigerator rf4287 power out for 5 days when power came back up display screen flashing 1 (or I ) and letter E
The IE error code is actually 1E. That stands for freezer sensor error. The sensor is reading open or shorted to the main pcb. You need to check the wire connections, from the sensor to the main pcb. I provided you a sensor temperature chart and wiring schematic on the images below. You will need a multimeter to perform the voltage checks. I hope this helps.
Image 1
Image 2
Image 3
Nov 02, 2012 | Refrigerators
Samsung RF4287HARS French Door Refrigerator Logo
18 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
