Question about Samsung RB1955 Bottom Freezer Refrigerator
My samsung rb195bsbb fridge alarm keeps going off and wont cool upper fridge
tborn6
  • 700 Answers
SOURCE: the fridge wont cool down
check to see if the freezewr evaportor is frozen up. you have to take the panel off inside of the freezer to see that all of the ice is gone,. but be carefull becaquse theres stryofoam inside that acts like a air duct to channel thee air across the coil the right way.
Posted on Mar 27, 2009
  • 106 Answers
SOURCE: I have a double door
check the condenor fan in the lower part
Posted on Nov 23, 2010
imufo2
  • 3773 Answers
SOURCE: Samsung side by side fridge/freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Posted on Aug 17, 2011
imufo2
  • 3773 Answers
SOURCE: the cooling power lights on my samsung fride
NOTE: This
But is probably a common defrost problem The ice build up
If
you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Posted on Sep 06, 2011
heatman101
  • 43501 Answers
SOURCE: my samsung fridge freezer wont
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 09, 2011
Need to turn off the alarm on my Samsung SRL551DP FRIDGE it refuses to change from 9 degrees and alarm keeps going off
You may be having cooling issues due to a defrost problem and the alarm is warning you of the problems
Appliance 911 Sea Breeze
Aug 27, 2015 | Samsung Refrigerators
How can I turn the door alarm off in my samsung fridge?
the alarm indicate that the door is open
check the door switch and check if the door press the switch or not
I think the door latch didn't reach the switch
Jun 07, 2014 | Samsung RS2630WW Side by Side Refrigerator
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Samsung RB195BSBB bottom freezer not cooling
If the ice buildup was by the pipe just going into the evaporator in the freezer compartment and the suction line going into the compressor is warm to the touch and not cold and/or sweating you are low on freon.
If the entire evaporator was buried in ice, the ice covering is also serving as an insulator and preventing internal temps from going down any further. There is a problem with the self defrosting mechanism which is designed to prevent the ice buildup. Could be either the defrost timer, defrost thermostat or the defrost heating element. Hope that it is just the heater element. If you have an electronic module for the rest you are in for unpleasant surprise to replace the unit. Proprietary parts mucho expensive plus labor.
Until you fix it, just let the unit manually defrost (U can use a hair dryer to speed it up) and turn it back on again. It will work fine till the ice builds back up. Keep opening and closing of freezer compartment to minimum to minimize moisture laden air that enters compartment.
Nov 24, 2013 | Refrigerators
We have a Samsung Fridge Model No: SL39WJ1/XEU - the door is alarmed but now the alarm keeps just going off - for 3 days now and now going off every few seconds. The temperature lights etc at top of...
Even though this video shows a different refrigerator model, I have seen this with Samsung refrigerators (mine for example). I hope this helps.
Nov 22, 2017 | Samsung Refrigerators
Water keeps dripping down from the upper compartment
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 13, 2011 | Samsung Refrigerators
How do i turn off the fridge so as to defrost the lower drawer freezer? rb195bsbb. it does not defrost which I guess impacts the feeble amount of ice from my ice maker
Just pull the power cord or circuit breaker as the refrigerator portion will keep cold enough for the 30 minutes it takes. Use a hair dryer with hose to defrost the lower box, get plenty of towels and go to work.
Feb 05, 2011 | Samsung Refrigerators
Fridge motor, I think, is making death rattle noises and the alarm keeps going off every few days
ck the cond fan as this is a very common problem . if its going to slow cooling will be poor and alarm will keep going off . / also dirty cond coils will cause poor cooling but not the noise .. mm
Jul 03, 2010 | Fisher and Paykel E522BLX Bottom Freezer...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
Samsung RB1955 Bottom Freezer Refrigerator Logo
116 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
