Question about Estate TAWX700JQ Top Load Washer
Grinding Noise When my washer starts the spin cycle it makes a grinding noise. I took the clothes out and turned it on again and the noise wasn't as loud, but still there? I thought maybe something was caught between the metal drum and the plastic tub, but now I'm wondering if maybe its a bearing.
  • 1,869 Answers
Yes you are right the tub bearing has failed
Posted on May 21, 2009
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Rtw4340sq0
Sounds like bearings are shot!!!call warranty company, let them sort it,,,it's normally quite expensive
Jun 17, 2013 | Washing Machines
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Washer is making a grinding noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag HAV2460AW Top Load Washer
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Estate TAWX700JQ Top Load Washer Logo
215 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
