Question about Kenwood KSC-WD250 Car Subwoofer
Kenwood CS-5370 100 MHz Oscilloscope channel "1" out of order.
I bought an used KENWOOD CS-5370 Oscilloscope and it seems channel "2" is working but channel "1" is out of order. When apply any signal to channel "1" its screen's trace simply disappears, it only returns when selecting channel "1" GROUNDED or switched to GND, what is the problem??? I need the Service manual to check the Channel "1" input and its circuitry, who help me?
tech48
  • 624 Answers
SOURCE: Kenwood - KDC-1020, Service Manual or
This is the standard Kenwood wiring harness from the service manual,
Let me know if you need more help.
I would appreciate a good rating if this was helpful to you.
Thanks
Posted on Jun 20, 2008
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
SOURCE: bought used car with kenwood
I JUST BUYA KENKOOD DNX 8120 FROM CAR TOYS INSTALL THE SECURITY CODE AND FORGOT IT. CAR TOYS IS CLOSE DO TO STORM.CAN SOMEONE HELP ME.
Posted on Sep 17, 2008
j_del
  • 1586 Answers
SOURCE: 2 problems, what are the
You can use the head unit with no remote - that's just an accessory. As for the wires, the red is switched power (this gets wired in so that it only has power when the key is on - when the key is off, it turns off the radio). The yellow is constant 12v power (to maintain power to the head unit so that memory settings, treble/bass settings, and the clock are maintained when the vehicle is shut off).
Posted on Sep 24, 2008
  • 150 Answers
SOURCE: Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
Posted on May 10, 2009
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
Peavey cs 200 X
Disconnect the input to the amp on the humming channel. If the hum still exists then there is probably a bias problem in the out put section. Check to see if there is a DC voltage on the speaker with no signal applied.
Jul 04, 2014 | Audio Players & Recorders
Kenwood TK-3302U16P ver 2
Search at internet by writting TK-3302U16 programming software
Feb 14, 2014 | Kenwood TK-3302U16P 450-470 MHz UHF 4 Watt...
I need to know what replacement antenna to get for my tk-3130
I found the manuals at:
http://www.hitechwireless.com/products/Kenwood-TK%252d3130-ProTalk-XLS.html
This radio is a UHF radio but it doesn't saw on the site what the frequencies are or the type of antenna connection, BNC, SMA, ?
The manual shows 464.5 MHz to 467.925 MHz so an antenna for 464 - 468 MHz would do.
Manual also at: http://kenwoodusa.com/
Contact form at: http://www.kenwoodusa.com/Contact/
See if they have a replacement antenna for you.
Oct 24, 2013 | Kenwood Protalk XLS TK-3130 (2 Channels)...
How do I set my comcast cable remote to the Kenwood cs 5.1 receiver?
These codes may work:
Depending on the comcast model remote you have: Some require the full 5 digit code while others only use the last four digits.
Codes for Kenwood receivers:
31313 31571 30027 31007
Most Direct, Comcast and COX remotes use the same basic codes either with or without the first digit which is always a 0,1, 2, or 3. (0 for cable boxes, 1 for TVs, 2 for DVDs, 3 for audio amps and receivers)
Hope this helps.
Jun 05, 2011 | Kenwood VR-507 Receiver
Hello! I have a dbx 223xl, the right channel is good, but the left channel doesn't work, all de cap and electronic component looks fine, nothigh seem burned out, but it's still doesn't work. What can you...
The only way to troubleshoot this effectively is to use an oscilloscope to signal trace. You can't tell much about electronic components unless they have external damage which often doesn't show.
Jan 10, 2011 | DBX 223xl Active Crossover (Stereo 2 Way...
Hello,I have four walkie talkie brand new from Kenwood, UBZ LF 14, and they work in the PMR band. Now I'm living in Italy and the PMR band is not allowed for family use by the Government The family...
Elio:
Your local Kenwood rep is correct for a couple of reasons:
1. The cost to modify your current radios to operate on the Italian band would be higher than the price of new radios.
2. Operating modified radios would be a violation of Italian laws.
Bill B
Nov 05, 2010 | Kenwood ProTalk UBZ-AM14 (14 Channels)...
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Car Audio & Video Logo
95 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
