Question about Husqvarna Sewing Machines
Not being notified when the bottom bobbin thread is running out
I have a husqvarna quilt designer II. It wont beep when the bottom bobbin thread is running out and it seems to be slow to let me know when the thread breaks. I have had it serviced and the repair man wasnt sure what the problem was. He thought maybe the sensor. He didnt have one in stock to try it. Any ideas? He tried some adjustments and a new bobbin case.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
There is a light sensor that "shines" through the bobbin and lets the computer know when your low on thread. If you were looking straight down on the bobbin it's beam runs from the 10 O'clock positoin to the 5 O'clock positoin straight through the bobbin. Sometimes lint gets in the way of the sensor on the left side.(the 10 O'clock side) Take out your bobbin case, turn the handwheel until the opening on the spinning thread hook in the machine exposes the 10 O'clock positoin and using a can of air or a compressor, blast that area to knock the lint out of the sensor. The sensor is located below the gray plastic housing to the left of your bobbin area. You won't be able to see it but you can see a slightly raised area in the plastic that covers it if you inspect the area. You have to tilt the machine back and look under the gray bed to see the "updent" in the plastic. Blow out that area for your best chance. Other than that It could be a number of adjustments and even a bad sensor. Good Luck
Posted on Oct 10, 2009
I am making a quilt on Husqvarna Lily 530 and cannot get my upper/lower thread equal for outlining design in quilt..book doesnot help me....any suggestions for stitch setting
Tension for stitching a quilt sandwich is tricky. It helps if you use the same color for top and bobbin thread,. If your quilting thread is not the same weight (either heavier or lighter) than thread used for regular sewing, then the bobbin tension may need to be adjusted. My quilting thread is lighter weight so I have a separate bobbin case whos tension has been adjusted specifically for quilting. The goal is have both threads meet in the middle of the sandwich. If the top thread is showing under the sandwich, you probably need to tighten the top tension so it will pull the bobbin thread up into the sandwich. Do the reverse if the bobbin thread shows on top.
It may also make a difference by changing the type and size needle. I tend to prefer a top-stitch needle. An embroidery or microtex may also work for you.
Machine Quilting Thread and Tension
Tension troubles on your quilting machine Try these tricks
5 Free Motion Quilting Problems and How to Fix Them
Mar 08, 2018 | Husqvarna Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
Husqvarna quilt designer II will not calibrate
Sounds like the touch screen has gone bad. You should take it to your nearest authorized husqvarnaviking dealer. You can find your nearest dealer at http://www.husqvarnaviking.com/us
May 11, 2014 | Husqvarna Sewing Machines
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
May 29, 2010 | Husqvarna Sewing Machines
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 23, 2009 | Husqvarna Viking 1
Husqvarna bobbin thread jamming
Make sure the bobbin thread "clicks" into the tension slot. However, thread nests underneath are usually caused by the top thread, not the bobbin. Make sure your thread is seating itself in the top tension disks. To do this, put the spool on the machine, pull off about 12 or 15 inches of thread, then hold this thread down with one finger on your right hand as you take the thread tail through the threading path with your left hand. When you get to the needle, tug the thread (still holding it down up top) to be sure it seats in the tensions disks. You must also have the presser foot UP while you do this to ensure that the tension disks are open. Watch the first thread guide after the spool as you sew to make sure the thread is not jumping out of there (a common problem with Des1 machines, fixed with SEs - no comfort to you and me!). I have put a small piece of tape across there with the end turned back on itself so no sticky bit is going to catch on the thread.
Mar 07, 2009 | Husqvarna Designer I
Breaking Thread
Use a bigger spool stopper to keep the thread from catching in the **** on the thread spool.
sewman7
Dec 22, 2008 | Husqvarna Viking 1
Husqvarna Viking #1plus bobbin problem
I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line
Dec 15, 2008 | Husqvarna Designer I
Hello I have a Husqvarna Quilt Design sewing machine. It workes great and Ihave it maintained once a year since I've owned it (5yrs) When I went to thread a bobbin it won't engage. The machine works...
Sounds like your bobbin winder has broken down, Kate. Nothing for it but to take it in for repair I'm afraid. It happens - you didn't necessarily do anything to break it - it is just a weak spot in these machines. I think everyone who owns one has had their bobbin winder repaired once, at the very minimum! (Coming up to repair No.3 for mine - luckily mine still winds, but just won't stop when the bobbin is full so I have to manually stop the machine.)
Pamsquilt
Jun 29, 2008 | Husqvarna Designer I
Sewing Machines Logo
111 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
