Question about Honeywell Programmable Thermostat Heater
Honeywell troubleshooting DISPLAY SHOWS (RECOVERY) AND IT TURNS THE HEAT UP BEFORE THE PROGRAMMED TIME. WHAT IS WRONG WITH IT
4 Suggested Answers
machtcl1
  • 61 Answers
SOURCE: heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Posted on Dec 16, 2008
  • 96 Answers
SOURCE: heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Posted on Dec 28, 2008
SOURCE: Honeywell T2060 UtilityPro Demand Control Thermostat
The user manuals don't show all the codes that the thermostat has....
If you can find an installer manual for this thermostat, or a similar one, it will provide the installer-only codes. Search for 69-1894ES.pdf - I think you want code 0530, and set it to 0. You access the installer codes by pressing two buttons - the ones each side of the centre button that you press for the user codes
Posted on Dec 04, 2010
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
Heater on when not programmed
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Heater comes on at 5:10 am prior to the programmed setting
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Adptive intelligent recovery
On the Pro4000 model you hold the 2 arrows until you go into setup mode. Then arrow up ONLY til you get to option 13. The display will read 13 and 1, press the DOWN arrow and it will read 13 and 0. This turns off Adaptive Intelligent recovery. Now hold the 2 arrows til you see the normal display screen. You are done.
I just did this with a Honeywell tech rep on the phone.
Nov 15, 2007 | Honeywell Programmable Thermostat Heater
Honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,175 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
