Question about Refrigerators
Ice maker is not working
Water is running out were cubes are form but the freezer is working
  • Victor
    Victor May 11, 2010
    HI, If the water is over flowing the oce maker, you might have to change the inlet valve. Did you have to shut the water off at the water source valve or did it shut off when you lifted the ice maker arm?
    Vic
  • 744 Answers
Hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
Posted on May 21, 2009
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
JSI-26 icemaker leaking water
You're ice maker is located on the left hand side of the freezer, if I'm correct.
Look to the back of the freezer slightly above the ice maker and you will see what they call the fill tube. Chances are ice has formed inside and when the ice maker goes to fill water sprays instead of flows out. In some models you can take the fill tube out from the back by removing two screws that hold it in, located at the upper right side if your behind it, and some you may have to pull out from inside.
May 07, 2012 | Kenmore 21.9 cu. ft. Side-By-Side...
Why is my freezer bottom forming ice. andd leaing water
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
The cubes are hollow and keep get stuck when they try dispence
The cubes are hollow? Means not enough water coming in on the fill cycle to fill the metal ice tray (netal form, see solution #2). There should be an adjustment under the end cover, looks like a screw with a spring around it. Look inside the cover and see if the directions are there for adjusting it properly.
Sep 19, 2009 | Whirlpool GD2SHGX Refrigerator
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Ice maker not making solid ice cubes
check your freezer temp and also if there is a water filter it might need to be changed
Dec 30, 2008 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
