Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Canon PIXMA MX 700 HAS ERROR 5100
I HAVE DOWN LOADED REG CURE. I ALREADY HAD THIS PROGRM ACTUALLY. I RAN IT, BUT THE SAME PROBLEM SHOWS UP. I CLEANED THE PLASTIC STRIP WITH ALCOHOL AND A SWAB, BUT THE PROBLEM PERSISTS
  • 4,041 Answers
Hi You can Try
Error Code 5100 Yes Same errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Error code 5100 on cannon pixma mp460 Does not load paper
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Sep 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
New printer canon pixma mx360....... when i pushed the botton on it says printer error has occurred 5100
Actually the printer is not actually loading the cartridge and showing you the Error 5100.
First of all turn off printer
then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
Jul 18, 2011 | Canon Pixma MX360 Printer
Good day! I have a canon pixma mp228 and have "5100" error code. Please help. thanks Francis
Error 5100 means that the cartridge can not be detected by the printer
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed but
If the problem is not resolved, then best option is to take it back where you purchased it or contact Canon service center about the error code or To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666)
They will surely solve it.
THANK YOU and Keep Visiting FixYa
May 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
5100 error message
  1. Turn off printer
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
Apr 11, 2011 | Canon PIXMA MP540 All-In-One InkJet...
ERROR 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
To solve these follow the following steps. I hope it works
  1. Turn off printer
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I am getting an error 5100 message. On the printer it says cartridge jammed thanks
Hello and WelcomeError 5100 means that the cartridge can not be detected by the printer.
  1. Turn off printer
If it is HELPFUL, Please Rate it as Four Thumbs THANKS
Mar 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 on Canon IP 2770
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
  • Turn off printer
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I have one printer canon Pixma IP90. Please advise me to solved : "Canon PIXMA iP90 Service error 5100". Thanks so much !
  • Turn off printer
Jan 29, 2011 | Canon PIXMA iP90 Mobile Printer
When I start my canon pixma MX 700 series I gets error code 5100
First of all, make sure you pay attention to when your warranty expires, because this error tends to repeat and you get disgusted and request warranty support only too late. The problem is probably caused by a sticky paper sensor, but the printer must be turned off and turned back on to reset. If it persists in displaying the error, then you should lift open the main part (scanner) look carefully in the back right for the black plastic piece that is the paper sensor and poke it with a narrow scissors or something to nudge it back down. Then turn it back on and hopefully it clears the error. However, if that's the problem then it will likely recur.
Mar 14, 2009 | Canon MX700 Office All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
