Question about Wurlitzer Jukebox CD Player
Error code for rowe ami jukebox - Wurlitzer Jukebox CD Player
  • 195 Answers
SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Posted on Feb 27, 2009
sirdotcom
SOURCE: I have rowe ami jukebox Eagle Laser Star and its
No don't do that. Take it to someone who services amps. They're all pretty much the same. Usually a couple of final-stage transistors are **** or the power supply is troubled. Good luck though!
Posted on Aug 19, 2009
  • 195 Answers
SOURCE: I have a Rowe AMI 100CD jukebox. Its making a loud
Hello camillemario,
The problem sounds as if there is a fault on the amplifier.
Pull the 110 volt plug from the power supply that feeds the amplifier.
If the amp is at fault and you are in the USA I would contact Bruce Wentworth for a test/repair to your amplifier.
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
Posted on Feb 26, 2010
  • 195 Answers
SOURCE: What is command 84 on Rowe Ami Jukebox
Command 084 relates to modem communications. This was intended for future use, 084 is Modem Is:
Regards
Alan Hood
ami-man
UK
Posted on Mar 26, 2010
SOURCE: Hi' I have just got a rowe ami r-83 disco jukebox.
you need to check the Home signal to make sure the opto is activated at position 99. When the unit powers up the mechanism scans one complete cycle so it re-indexes the computer and starts scanning from position 00. If you want a quick test, turn the power off and scan the carousel to position 99 by releasing the latch on the left side of the mech just under and behind the mechanism motor. then power up the unit and it should pick the right selection. You can also observe the optic indicators on the mechanism control board under the turntable. The Home signal only operates at 99, the Index pulses between each record as it scans. Good Luck
Posted on Dec 02, 2010
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
alan-hood@datex.co.uk
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
I have a Rowe AMI 100CD jukebox. Its making a loud buzzing noise when I plug it in. Everything else works except the loud noise that I have to unplug it right sway. Do you think it is the red button fuse,...
Hello camillemario,
Regards
Alan Hood
ami-man
UK
Feb 21, 2010 | Wurlitzer Jukebox 1015 One More Time...
Rowe Ami R-80 imperial jukebox
Hello Andy,
Yes I know the 1976 Rowe Ami R-80 jukebox very well as well as most of the other Rowe Ami jukeboxes.
The turntable motor and the lighting work off of the 110 volt output from the power supply.
The other power voltages are connected to the power supply via the molex plug.
Pin 1 30VDC white/red
Pin 2 30VAC yellow/black
Pin 3 Common black
Pin 4 Ground gren/yellow
Pin 5 No connection
Pin 6 Common black
All the voltages are protected by circuit breakers.
I assume that you may be in the UK if this is the case here are my contact details.
Alan Hood (ami-man)
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Jan 20, 2010 | Vintage Jukebox External Speakers Shelf...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Mar 10, 2009 | Wurlitzer Jukebox CD Player
Song Programming
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
27 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
