Question about GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker No Spin
I have a GE Spacemaker washing machine model WSKS2060W1WH. It works works perfectly until it reaches spin cycle. It drains after wash and then when the spin is suppose to kick in I just hear a 'loud click' and the drum starts to turn but stops right away. I thought the brake was stuck on, but I know it is releasing as I can watch it from the back side. The brake releases and then just re-engages. So just for grins I thought I would take the spring off the brake to see if it would work for whatever reason, and it still just gives me a 'loud click', like a contact on a relay is bad? Am I getting close to the solution? Where is this relay located to see if I can fix it? Or is it even a relay problem? What part am I looking for? This problem will occur whether you use normal wash cycle or just manually turn the dial to 'spin' selection. I hope someone can help me as I really need this going right away. Thank you in advance for your help. Gary brake seems to be stuck on, or is belt too loose? motor is extremely hot and smells burnning a bit? what is the problem here most likely? clothes are x tra wet from the lack of spin and draining on the spin cycle how/ what do i check voltage or continuity of motor??? thank you ..............gavin
  • Anonymous May 24, 2009
    I have the same Problem... It is not the lid switch on top. Anyone have another solution???
  • partonken May 25, 2009
    ive got the same problem! no spin but everything else. There is also a burning smell as well. it also occurs when you manually set the switch to spin on the control dial.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Most washers use a lid switch that closes the contacts when the lid is closed, look for a "probe" on the lid that pushes a "pad" that closes the switch, it's possible the switch pad or linkage is bent causing erratic contact closing, any way that is the first place to start. THIS IS A SAFETY DEVICE, DO NOT BI-PASS IT. Good Luck
Posted on May 21, 2009
2 Suggested Answers
  • 883 Answers
SOURCE: GE Spacemaker No Spin
yes, you are getting close to the solution. the loud click may be an over-current relay that is sensing above normal current leading to the high speed winding of the motor. unplug the motor and test the motor for shorting. also check wiring for chafing to chassis. if all above ok, then do a "dry test" by unplugging motor and running machine with voltmeter on motor plug...are you getting correct voltage to drive motor?
Posted on Aug 12, 2007
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
When the washer gets to the spin cycle it seems to stop and not pump out the water. All other cycles seem to work ok. It is a GE spacemaster 22"
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Water is not draining?
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
the washer has carbon brushes on the motor if these are low the drum will not spin it needs these carbons to make contact with the motor
Aug 12, 2007 | GE WSKS2060WWH Top Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
642 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
