Question about Cobra 29 LX 40-Channel CB Radio with Instant Access 10 NOAA Weather
Radiocheck shows rf output power failure - Cobra 29 LX 40-Channel CB Radio with Instant Access 10 NOAA Weather
    Genius:
  • Cobra Master
  • 1,795 Answers
Its an inside the radio fix mine is doing the same thing and I have had the time to get into it and fix it.
Posted on Sep 01, 2014
My 2005 Lincoln navigator has a new compressor and it lifts up but I must restart it to get it to lift. could you please tell me why
Have to restart what ? Vehicle ? Did you have the system check for code's ?
The four wheel air suspension system is comprised of the following components:
  • Service switch
  • Control module
  • Two front height sensors
  • One rear height sensor
  • Compressor and drier assembly (includes vent solenoid)
  • Air lines
  • Front and rear air spring and shock absorber assemblies
  • Four air spring solenoids
  • Compressor relay
  • Vehicle Dynamic Module (VDM) Diagnostic Trouble Code (DTC) Index NOTE: Repair all other DTCs before C1725 and C1726. Repair DTCs C1990 and C1991 last. DTCs Description Source Action B1317 Battery voltage high VDM Go To Pinpoint Test C . B1318 Battery voltage low VDM Go To Pinpoint Test C . B1342 ECU is defective VDM INSTALL a new VDM. REFER to Air Suspension Control Module in this section. SET the ride height. REFER to Ride Height Adjustments in this section. CARRY OUT the pneumatic test. TEST the system for normal operation. B2477 VAPS II steering assist curve not complete VDM REFER to Section 211-00 . C1445 Vehicle speed signal circuit failure VDM GO to Symptom Chart . C1724 Air suspension height sensor power circuit failure VDM Go To Pinpoint Test D . C1725 Air suspension front pneumatic failure VDM Go To Pinpoint Test E . C1726 Air suspension rear pneumatic failure VDM Go To Pinpoint Test E . C1760 Air suspension rear height sensor signal circuit failure VDM Go To Pinpoint Test F . C1770 Air suspension vent solenoid output circuit failure VDM Go To Pinpoint Test G . C1790 Air suspension LR air spring/shock solenoid output circuit failure VDM Go To Pinpoint Test H . C1795 Air suspension RR air spring/shock solenoid output circuit failure VDM Go To Pinpoint Test H . C1830 Air suspension compressor relay circuit failure VDM Go To Pinpoint Test I . C1840 Air suspension disable switch circuit failure VDM Go To Pinpoint Test J . C1873 Air suspension RF air spring solenoid output circuit failure VDM Go To Pinpoint Test H . C1877 Air suspension LF air spring solenoid output circuit failure VDM Go To Pinpoint Test H . C1881 Air suspension RF height sensor circuit failure VDM Go To Pinpoint Test F . C1889 Air suspension LF height sensor circuit failure VDM Go To Pinpoint Test F . C1897 Steering VAPS circuit loop failure VDM REFER to Section 211-00 . C1964 Air suspension compressor actual run time exceeded allowed run time VDM Allow the air compressor to cool down. CLEAR the DTC. REPEAT the self-test. C1990 New control module initialization (requires ride height calibration and pneumatic test pass) VDM REFER to "Clearing DTC C1990 or C1991". C1991 Plant ride height setting and/or tests incomplete VDM REFER to "Clearing DTC C1990 or C1991".
May 23, 2018 | Lincoln Cars & Trucks
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
What should pwr ant knob be adjusted to?
The PWR/AMT knob:
PWR: Variable RF Output Power. The transmitted power of the Magnum S-6 may be varied from 0 to 40 watts peak in all modes. Rotate clockwise to increase RF output power. Rotate counterclockwise to decrease RF output power.
AMT: All Mode Talk Back. AMT, a Magnum exclusive, is an independent talk back monitor. The AMT functions in all modes and allows the operator to monitor the trans- mitted audio of the Magnum S-6. To increase the vol- ume of the talk back rotate the control clockwise. To decrease rotate counterclockwise. To turn off the talk back rotate the control completely counterclockwise.
Apr 22, 2017 | Car Audio & Video
Receives,no Tx
Many possibilities:
1: The radio took a hit and broke the PCB or the connection to the RF out jack.
2: Some other PCB joint failure
3: The RF output IC is toast
4: The driver is toast
5: The tx oscillator is so far out of whack it cannot develop the frequency it is set to.
6: You have a bad cable or antenna connector
7: You have a bad battery, battery contact or power connection
8: You have a power supply or other problem
Sep 26, 2015 | Icom IC-T7H VHF/UHF Handheld Dual Band...
Rci 2995dxrci2995 low rf output
you need to buy a new one or show it to an electronics engineer ...if it is good(not damaged) but you are asking how to increase its rf output power then an electronics engineer might design a custom electronic circuit with RF amplifier that provides higher output power.....also you might want to check out the rules regarding the power you are allowed to use in your country....
class AB Power Amplifier Design and Simulation
Jan 25, 2014 | Radio Communications
Truck usually starts and runs fine but sometimes when I turn on the key absoulutelly nothing happens
nothing as no lights radiocheck ignition switch or nothing as in starter check relay and power at solenoid on starter when switch is in start position no power check relay have power replace starter
Jan 10, 2011 | Mitsubishi Mighty Max Cars & Trucks
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Tv digieye
Hi.
At the back of the box there will be 2 rf outputs.
What you are looking for is the rf output 2. What you need to do is connect a rf cable from rf output 2 into the magic eye,which in turn plugs into the rf input on the tv.
To make sure that the 9v signal is being passed up the cable(this is what allows the magic eye to work)
go into services on the SKY guide the press 4(system set up) then 01 select. This will give you access to the installers menu. Press 4 (rf outlets) and then make sure that power supply is ON. Save new settings.
This will now let you use a magic eye.
http://dysonmanuals.llc.nu/
Chris.
Mar 11, 2008 | Televison & Video
Cobra 29 LX 40-Channel CB Radio with Instant Access 10 NOAA Weather Logo
138 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
