Question about Frigidaire Washing Machines
Washer only runs far 2 min then stops - Frigidaire Washing Machines
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: calypso washer starts runs for 2 min stops then starts then stops the starts and c1 flashes
The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nut-ate plate or between the spin basket and the outer tube of the washer could also cause this problem.
Posted on Nov 22, 2012
Washer runs great for about 3-4 min than shuts down. Motor runs as long as I do not ingage the nozzle.
Recently I have a similar problem, with a easy solution, just don't push the accelerator nob all the way, leave a 1/4 before reach full power. Apparently some times there is a bad calibration an make the carburetor over flow and lost power.
Sep 11, 2014 | Garden
My maytag dishwasher will run for a short then stop running, I'll push on the door the machine will run again then will stop again
your door is not staying latched.. imagine if it did stay running and the door came completely open, what a mess that would be. so there are safety switches that help stop the washing if the door opens. not too sure how to fix your exact washer.. but the problem is the door not staying closed. maybe you can jamm the door shut while it is running? its not the best answer, but probably the most free way to fix it
Oct 29, 2013 | Dishwashers
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 98702 Stacked Washer keeps stopping, and a smell of smoke.
More than likely there is something locking up your motor. Either the transmission or the drain pump, both are connected to the motor. The easiest way is to disconnect the components from the motor to determine which one is causing the problem. Most of the time it is from the something being lodged in the pump, a sock, screw, wire, etc. To get to the pump you need to tip the washer back far enough to get underneath the washer.
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag SAV 205 DAWW
Look for a self resetting overload on the motor. many motors have an overload that pops a little red button out and waits for a push to reset. Other overloads will reset automatically because they are hard to access for pushing a button. If there is an overload resulting in a shutdown you will have to determine the cause. I have found motors in washers completely ingulfed in dust and lint (from the adjacent dryer) and not being allowed to dissipate heat. Sometimes a thorough cleaning is all that it needs to run cool and efficiently.
Jan 18, 2008 | Maytag Legacy Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
