Question about LG WM-3677HW Front Load Washer / Dryer
I have a Tromm Ultra Capacity model number wm3677hw and it won't drain. It's over 5 years old and has occasionally had this problem but emptying it isn't helping this time. Ideas?
  • 105 Answers
SOURCE: TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Posted on Jan 28, 2008
  • 16 Answers
SOURCE: LE error
try using a-fresh its should help you out.
Posted on Nov 03, 2008
skimbot
  • 5 Answers
SOURCE: I HAVE AN LG TROMM WM3677HW AND I AM GETTING AN IE
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
Posted on May 30, 2010
SOURCE: My LG Tromm washer dryer ( WM3677HW or WD-12270RD)
According to the manual "water is overflowing (water level frequency is over 213). If FE is displayed, the drain pump will operate to drain the water automatically". Since there's nothing between the water inlet valves and the PWB I'd suspect that, but not before putting it into Test Mode to rule out other components and especially checking the water level detector switch
The water level detector switch monitors the water level and feeds this information to the MICOM. The sensor reads air pressure in an air chamber on
the tub. The air pressure changes in relation to the depth of the water, moving a diaphragm in the switch. As the water level fluctuates, it raises or lowers the iron center in the coil, which, in turn, changes the electric resonance of the oscillator circuit of which it is a part. As water level decreases, frequency increases. (e.g. A low water level may read 25.5kHz1 while a high water level may read 21.4 kHz. These readings are approximate; washers in the field may vary slightly from these figures.)
To read the frequency while the COMBO is running, press and hold the SPIN SPEED and SOIL LEVEL buttons. The number on the display should be divided
by 10 to obtain the frequency reading in kHz. A display of 254 would indicate a frequency of 25.4 kHz. The MICOM interprets the frequency reading as one of
eight levels, with one being the lowest water level and any level greater than eight indicating an overflow situation.
Posted on Jan 04, 2011
mc1bean
  • 3053 Answers
SOURCE: lg tromm wm3677hw wont dry my clothes
Hello, pastor
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
Batteries drain very quickly
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 06, 2012 | Fuji FinePix S9500 Zoom Digital Camera
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
My battery level reduce with in a day after full charge so how to solve the draining problem of my 5800nokia?
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 04, 2011 | Nokia 5800 XpressMusic Smartphone
Why its battery quickly drains
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
Hiii , How are you today ? I have phone model is Nokia N86 ,My problem is after charger my battery full , maximum after 3 hours i receive message from my phone ,The message is Power saving mode...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 18, 2011 | Cell Phones
I have a 5 year old Kenmore Ultra Guard Elit eQuiet wash 7. Seems to wash ok buut very loud all the time now. Do I need to replace motor or would a clogged drain make it do that.I don't notice a problem...
This would indicate a bad motor, very common on these units. You can purchase the motor from the link below. Type your model number into the part search box for a parts diagram and part numbers.
Appliance & Refrigerator Repair
Mar 23, 2011 | Kenmore Dishwashers
LE error
Oct 12, 2008 | LG WM2688HWM TROMM SteamWasher
Tromm drain pump wm3677hw
you may be able to find parts outside the manufacturers realm.
I would call Tromm, and ask for a supervisor and show them that it started before the warranty was up!
Almost every manufacturer will send someone to help you for free or do whats called a, "PUSH-PULL"
If there is a lemon or the customer is ********** cause the unit broke to many times and he got no satisfaction.The manufacturers will send a dealer to deliver a new one and take the lemon away for free. They pay the dealer they arrange this with!
We do it when ever they ask us to for all the manufacturers.
YOU PAY NOTHING ,except a tip to the delivery guys if you want to!
Discount Parts Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Sep 05, 2008 | Washing Machines
Tromm won,t drain
Peace,
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if this reboots the system like when a computer acts up, we do the same thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see what they tell you for this specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-3677HW Front Load Washer / Dryer Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
