Question about HP PSC 1610 All-In-One Printer, Scanner and Copier
Will not power up after months of great service. All cables checked.
Printer does not power up. Suddenly after months of good service, I cannot turn it on. AC plugged, both cables in, everything checked, still no power.
  • 52 Answers
First check if you get power at both ends of cable, i.e. wall socket and the plug that goes into the printer, you'll need a voltmeter to check that.
Posted on May 21, 2009
A problem with epson artisan 810
  1. Turn the printer off, then disconnect the power and the interface cable. Open the cover and check for any torn or jammed paper and remove it.
  2. Reconnect the power cable and turn the printer back on.
  3. Press the Copy button and see if the unit responds.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 08, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Lexmark 5600 printer will not turn on
Try pressing the power a little longer for the printer to start.
Jan 03, 2014 | Lexmark Office Equipment & Supplies
Hi, I have an HP Officejet L7780. It prints perfectly with no issues at all however when I turn it on it takes about 13 minutes to finish it's loading/diagnostics. I get the message " Checking...
I Would recommend performing a partial reset on the printer, so that printer will initialise completly after resetting.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Regards
Riztech
May 23, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Pixma 810: Suddenly the printer is dead. Despite power cable is connected with Pixma I can no longer turn the printer on. Is there a fuse anywhere? What is the solution? Best regards Peter Widmer
Hi
First of all please make sure that all the cables from/to the printer are connected properly. Now please use different power socket to make sure that the printer is getting power. If so then we can reset the printer. To reset the printer unplug it from/to the power socket and mains and let it sit without power for more then 10 minutes and then replace all the cables and print a test page. If still the issue is not resolved then you'll need to replace the printer cable. Hope this helps...please post back for further assistance.
Daniel
May 19, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I was replacing the cartridge when the printer suddenly turned off and does not turn on again
try to check if the power cable has been abruptly disconnected. Also check USB cables that are connected to the HP Printers if they are disconnected. Maybe that is the reason your printer suddenly turns off..
Nov 08, 2010 | HP Office Equipment & Supplies
Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Jun 22, 2010 | HP Photosmart C3180 All-In-One InkJet...
Xerox 8500 not printing
It sounds like you need to check your addressing. Sounds to me like your IP address reset back to default.
You need to go into the network settings and check your IP address and make sure it is set to manual and not auto.
I believe your printer did a reset and your address is wrong.
Jun 27, 2008 | Xerox Phaser 8500/DN Printer
Mp530 printer, no power , no lights or beeps
This just happened to our Canon MP530, which was about 10 months old. I called Canon support and they said they'd send a new power cord to us. Then, if that didn't work, they said they'd replace the unit. Well, turns out we found a replacement power cord ourselves and tried it - amazingly, the printer now works. So if this happens to your unit, try replacing the power cord. It may just fix the problem.
Apr 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Mar 18, 2008 | Computers & Internet
HP Laser Jet 4L - No Power
it's possible that the power switch alone just needs cleaning. Take it apart down to seeing the copper contacts and then polish the copper contacts with emory cloth.
Sep 09, 2007 | HP LaserJet 4L Printer
37 people viewed this question
Seeker5211
Seeker5211
