Question about Samsung HLR5064W DLP Projection TV
My set is the SAMSUNG LHP5063W. I replaced the color wheel Sunday and got horrible colors. The Part number ordered was BP96-00674A The number on top of the color wheel top is L3 BP61-01687A but I do n
My set is the LHP5063W. I replaced the color wheel Sunday and got horrible colors. The Part number ordered was BP96-00674A The number on top of the color wheel top is L3 BP61-01687A but I do not know if this is significant. My DMD board has no yellow and white sticker and no jumper. To get to service mode where I could enter CCA codes, I used the sequence POWER OFF MUTE-1-8-2-POWER and got 10 options starting with 1 DDP1011. Selecting the DDP1011, I got NOT AVAILABLE, followed by the same response for the other 9 options. How do I get my proper colors back?
  • Anonymous May 21, 2009
    No instructions came with the replacement color wheel for the HLP5063WX, just the packing slip. I'm mystified that the service mode gives a return message NOT AVAILABLE. Doesn't the color wheel simply rotate at a default rate without any input?
  • John Snow
    John Snow May 11, 2010
    Did the color wheel come with instructions to change the speed of the color wheel?
  • 6,784 Answers
The new color wheel is different from the original. The original used an Air Bearing type motor. But the replacement type is a standard bushing type motor. There is a jumper on the rear of the DMD board that may or may not be covered with a paper sticker. Reposition the jumper to accommodate the new color wheel.
Posted on May 21, 2009
  • paulhinz Nov 07, 2010
    This fixed it for me. I had easily replaced the color wheel and had the color problem (startup screen looked orange instead of blue) and I had seen a couple posts about removing a jumper but could not find it.
    Your tip to look behind a paper sticker I was able to find the jumper and remove it. Note - my jumper was below the paper sticker.
    Thanks. Paul
  • 25 Answers
I installed one also and my pink iblue and my blue is pink and the blue dominates the picture,these colorwheel marked BP96-00674a look exactly like the BP96-01103a,
Posted on May 27, 2010
Fan makes a horrible noise
Thats Not the Fan its your Color Wheel ,Google to Encompass Parts Distribution they will list Parts for this Model number
Color Wheel PN# BP96-00674A Price $123.00
1-800-638-3328
Sep 20, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
High frequency noise
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
Sep 11, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
May 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
My samsung 5063w turns on and the screen is bright, no noise but the color is "faded" for lack of a better word? what could be the problem?
Reset all ur setting back to factory setting.Still same problems,might be the colors wheel is not woking right anymore.
Mar 26, 2010 | Samsung DLP HL-P5663W 56" TV
Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
Oct 30, 2009 | Samsung HL-R4667W Rear Projection...
I have a samsung dlp that makes a horrible buzzing sound and it turns off, all the lights blink and the color flashes in and out.
The problem is likely the color wheel paste the link attached for more info
Samsung Color Wheel
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 5067W makes a horrible noice when it comes on. In fact, it sometimes does not want to come on at all. I have read that it could be the color wheel. Can you tell me?
color wheels usually make a low squeling noise when going bad,I have had them cause a unit to shut off.your part number is BP96-00674A for the color wheel.
Sep 24, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung lcd tv
You have a defective color wheel. Its not easy to change. You must be familiar with the Lite engine. This TV carries 2 types of Color wheel. Look at the side of the TV for your version number to see which one it uses.
(1) Part number BP96-00674A COLOR WHEEL (FOR TYPE L3 VERSION PW03 UNITS)
(2) Part number BP96-01103A COLOR WHEEL FOR TYPE L6 VERSION PU01 UNITS
Best regards
CircuitCity
Dec 07, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLR5064W DLP Projection TV Logo
1,009 people viewed this question
Henry  Thomas
Henry Thomas
