Question about Bear Purple Bear Check Blouse Se
What size is 0X - Bear Purple Bear Check Blouse Se
The error says "Application has generated an exception that could not be handled. Process id=0x (a series of numbers that change), Thread id=0x (numbers that change). Click OK to terminate the applica
did you add any new hardware or software just before this error started. If this is a Windows PC you can go into the safe mode and remove the bad software. You can also (if you can) remove or disable the hardware. Reboot into the PC as normal and see if you are still getting the error.
Jul 31, 2013 | Computers & Internet
Tip
0x error
No matters which printer you are using if you get any error like 0x*****
please please donot perform any steps...please call HP teach support on 1800-474-6836...and if its needed they will replace the printer..
on Jan 21, 2010 | Office Equipment & Supplies
MS office power point 2007 gives error 0x 0000008
Be sure your computer is compatible for 2007. Check memory size. Do on-line updates at Microsoft Updates. If all else fails, reload the program.
Aug 12, 2010 | Computers & Internet
STOP:c0000005 The instruction at 0x%081x referenced memory at 0x%081.The memory could not be %s. This message appearing on laptop screen - cannot do anything with it now!
There are a lot of cause to this error message. But mostly software. If you back up your files. I suggest to perform factory image recovery and restore the computer to factory default setting.
Jul 21, 2010 | Dell Inspiron 6000 Notebook
I have ink error OXC18aOOO1. Any idea of what I should do or how to clean the printer head, it won't pull over so I can get at the printer head. Thanks David
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET OR THE PRINTER NEEDS TO BE SERVICED
Mar 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
Blue screen of death
Hello
Well, that spesific error mesage is because of a hard drive failure. I notice that this same problem occurs more in portable devices, such as laptops. The thing is, that if the laptop was droped during the days previous of this error, the mechanism will still run but the disc will have so many bad sectors that you will not be abvle to use it anymore.
I would suggest that you try formatting the drive first and see if it works, otherwise get a new drive. Hope this can help you.
Best regards
Andrea
Nov 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Blue screen appears have to run in safe mode, dell inserion laptop with vista
The blue screen error will have a code something like 0X******** (0X*******............). You can either comment the error code here or you may also check the same in the microsoft website. It will have a solution as well.
Good luck !
Aug 28, 2009 | Dell Computers & Internet
A problem has been detcted and windows had been shut down to prevent damage to your compuetr
This is a windows stop error. Are you running windows XP?
If it is the first time you have seen it you can try restarting and it may never appear again. If it does:
At the bottom of the screen you will see some text saying STOP ERROR: 0x000000?? (0x???????? 0x???????? 0x???????? 0x????????)
Look at the code prior to the brackets 0x000000?? - write it down and google "STOP ERROR 0x000000??".
This will let you know what is causing the STOP error. Very common reasons for this are component reseating required and disk-checking. You can run a diskcheck through the Windows Recovery Console (can be installed to hard-disk - simplest way is to install combofix and follow the onscreen instructions - or run from your windows installation disc).
Jul 23, 2009 | Dell Dimension 9200 PC Desktop
Can't get past bios post
If you can't even pass the POST your only option is attempt to flash the BIOS. Go to your motherboard manufacturer's website to find updated BIOS and instructions for your particular board.
Apr 08, 2009 | Acer Computers & Internet
Bear Purple Bear Check Blouse Se Logo
43 people viewed this question
Top Bear Toys Experts
noel
noel
Are you a Bear Toy Expert? Answer questions, earn points and help others
