Question about Refrigerators
We have a fridge and a separate freezer integrated into a 50/50 Mfi tower unit.an APM6713 k an APM6656 freezer., they measure 53cm wide across their doors, but all the ones I am seeing for sale are W54cm. I have measured inside unit side panel to side panel is 56cm. If I purchase a replacement at 54cm wide I am concerned the appliance door will clash against the tower unit hinges. What is the replacement brand I need to fit an old MFI tower please? Many thanks Neil
4 Suggested Answers
  • 77 Answers
SOURCE: I need to track down
Contact local part supply house and ask for "fit-all" gasket kits. comes with 2 Corners that have long sides that can be cut to fit. not perfect but when original is NLA all you can do.
Jim
Posted on Jul 28, 2008
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
  • 64 Answers
SOURCE: How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Posted on Oct 06, 2014
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Old:
New:
Oct 06, 2014 | Refrigerators
I have a Matag Refrigerator Model MTB2156DEW. The freezer is located on the top of the fresh food compartment. For approximately a week the refrigerator has been constantly running without cycling. ...
Defrost the unit. The fridge section cannot cool if the freezer is iced over since the fridge gets its cold from the freezer. If you don't have a second fridge use a hair dryer to speed the defrost.
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
I need a fridge freezer with external measurements H164cmxW73cmxD56cm. H could go up to 170cm. I want max freezer space, so at least 50/50split
You are going to have to do your own leg work on this one I think. Maybe somebody here can answer that question, however this is a repair forum and I can't memorize the dimensions of every possible fridge out there. My suggestion is to bring a tape measure with you to the appliance store of your choice, or look at online catalogs, they may actually list the dimensions you seek.
Oct 03, 2010 | Freezers
I don't need deep freezer. I want to disconnect it and deinstall deep freezer from Refrigerator. Pls. guide. I suppose this will reduce my electricity bill. Am I correct ?
With most units you can't do that. The fridge gets it's cold air from the freezer side. The air is blown through a vent at the top. Samsung is one kind that has a separate unit for fridge and freezer and could possible be cut off separately but most can not.
Aug 10, 2010 | Refrigerators
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
How msny cubic ft. is my 106.9750610 Kenmore refrigerator?
I tried downloading a manual for your Kenmore Top-mount refrigerator-freezer but it is no-longer available. the next best way is to measure the inside dimensions of your refrigerator. Measure the depth, height and width in inches. Times them together and divide by 1728.
example: if your inside of your refigerator is 30 inches wide by 20 inched deep by 50 inches tall you get 30 x 50 x 20 = 30000 cuin / 1728 = 17.36 cuft. Do the freezer section seperate to know thier individual measurements and add them together to get the total. I hope this helps. - subdriver
Mar 25, 2010 | Refrigerators
Freezer cold fridge warm
clean the condenser coil in the back of the unit
Apr 20, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
