Question about GE JVM1851BD 1100 Watts Microwave Oven
Manual xl - GE JVM1851BD 1100 Watts Microwave Oven
Need xl-1800 manual
You can download GE owner's manuals and installation instructions here.
Sep 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE spacemaker XL. When running, it seems
http://www.retrevo.com/support/GE-JVM1640SJ-Microwaves-manual/id/1080ci954/t/2/
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need an instruction manual for spacemaker XL Sensor JVM1350BW, made in 1997
Go to managemyhome.com and type your model number under the "Manuals" link. You owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Sep 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL Microwave Oven Model #JVM1460WA1- After removing the 3 bolts at the top, what are the next steps to remove the oven?
Jun 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to install oven to wall
Dec 28, 2008 | GE JVM1651 Microwave Oven
Can't get Demo Mode Off
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Otherwise, you might see if this is addressed in your owner's manual.
If for some reason you don't have your owner's manual, you can download GE owner's manuals and installation instructions here.
Dec 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be...
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cant figure out how to stop the timer before it goes out, or runs out of time
You should be able to hit the Stop pad, but you can download GE owner's manuals and installation instructions here.
If some of the pads on the keypad are not working, you may have a failed keypad, which can be replaced.
If so, please reply back with your model number and let us know.
Sep 28, 2008 | GE XL1800 1100 Watts Microwave Oven
How do I install the Spacemaker Xl? Where does the cord go?
You'll need your model number from the tag.
Aug 07, 2008 | GE Spacemaker Over-the-Range Microwave
Does anyone know where i could obtain a manual for a GE 1800 XL - my brother gave this to me but he didn't have the manual
Enter the full model number here:
http://www.geappliances.com/service_and_support/literature/
Note that XL1800 is not the model number, but it is located on a tag / sticker and should be something like JVM18xxxxx, etc.
Nov 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1851BD 1100 Watts Microwave Oven Logo
61 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
