Question about Microwave Ovens
Whirlpool RF302BXGW left front element not functioning
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
Looking for a replacement element for my cooktop Thermador CHCV30 Front left element. Seems hard to find any ideas?
Hello
the best will be to remove the element ant take it in as a sample so that they can bend you a new on to fit there
thanks
Jun 08, 2011 | Microwave Ovens
Surface burners , when turning on left front the left back burner comes on,
You should first check the wiring on your knob to be very sure that it is not malfunctioning or having partial contact by touching the back burner mapping or control. if everything is okay there, then you van check the below as well but if not, please fix the partial contact on the knob.
Secondly,Inspect the element to determine whether it plugs into a receptacle, as most do, or is wired directly.
Remove the plug-in element and inspect the prongs: Lift up the front of the element, then pull the element straight out.Check to see if the prongs are burned, pitted or otherwise damaged. If they are, you'll need to replace the element and the receptacle.
Take care.
May 15, 2010 | Microwave Ovens
Doesnt heat up
hello
this simple thing that you can handle your self
this means that there is disconnection from the maize to the element
what you need to do from here is that you have to unscroll your microwave to locate the maize that is the wire that is suppose to connect to the element this means the heat provider
these wire could be three or two,, red white and black depending on the factory production
please note this, make sure that your microwave is unplug to any form of power supply before you can carry out this function .
thank you and thanks for using fixya and god bless you.
Apr 30, 2010 | Whirlpool MH1170XS Microwave Oven
Whirlpool rangge radiant element stopped working
It may be a bad element, a bad control switch or a bad infinite switch.
There should be a technical sheet on the back or inside of the oven. Or you can find it here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 07, 2009 | Whirlpool Microwave Ovens
Whirlpool MH7130XEB-1 blows 20a line fuse when I use the oven. no problems with any other functions of the microwave
hi,you need to check wires to the bake element or broil are not touching the metal case...check your power cord going into the back were the wires hook up...you have a direct short....check your switches carefully....i hope this helps....
Nov 05, 2009 | Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Whirlpool RM280PXAQO power loss to one leg of bake element
remove leads from heater and carry out resistance test to see if heater is ok. you have checked the voltage so presume you have a meter.if not test voltage on both sides of heater connect directly to ground and other lead on ground of heater you should have a voltage if not you have a ground fault
Feb 18, 2009 | Microwave Ovens
Whirlpool Microwave oven 1000w
how can i remove the front glass on my whirlpool microwave
Mar 31, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
