Question about NAD Audio Players & Recorders
Nad t758 remote code
Nad T 512 original code
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 22, 2014 | NAD T 515 DVD Player
I have a Nad T760 receiver/amp (not sure what the difference is). The remote cannot function. Is there a universal remote that I can buy? As this is quite an old piece of kit not sure if there is a
some remotes can be programmed by entering a manufacturers code using the numeric keys. i use a Sony RM-VLZ620 remote. it lists NAD as a supported receiver.
P.S. - a receiver is an amplifier with a built in radio tuner.
Nov 15, 2014 | NAD T760
I have an HTR-2 NAD remote. All the buttons except for the ON button are working. is there anyway to fix this?
Remote controls have an operating code which entered right will cause all functions to work. However if you were given the wrong remote or it doesn't have the right code, certain buttons will not work.
Check that the appliance it operates is the right model for the remote. Some remotes will allow reprograming others are fixed. If you can reprogram it will be just a question of finding out which code the amp uses and entering that. You can search online for the codes for your model.
It's not uncommon for the wrong remote to be sent out when first sold. Some people don't know it's wrong as the remote works nearly all the functions, just not all.
Aug 02, 2014 | NAD Audio Players & Recorders
HDMI problems with NAD T758
Yes because HDMI 1 is the only hdmi port on your TV that has ARC. I Believe if you turn down the resolution (the quality of the picture) in the settings on your DVD player it will work on the other hdmi ports. This of course is probably the last thing you want to do. That's technology for you.
Mar 01, 2014 | NAD Audio Players & Recorders
Need codes to program a urc-4021Boo universal remote to a NAD receiver
0285,0280,0288. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electro-medical.blogspot.com/
Dec 31, 2013 | Televison & Video
NAD T754
Sometimes manufacturers change codes from time to time and functions that the remote controlled yeasterday can't be controlled today. You might be able to get some functionality out of another universal remote with a more extensive library of codes available. I understand your frustration - I have a bunch of useless remotes as proof.
Dec 10, 2013 | Audio Players & Recorders
I have a T754 which has worked great since day 1 - then i lost IR control. Checked my remote and it is putting out the correct codes and works with another NAD Recv fine. The problem must be in the RECV...
Batteries are flat or incorrectly inserted
• IR transmitter window on remote, or IR receiver window on T 754 is obstructed
• T 754 front panel is in very bright sunlight or ambient light
Troubleshooting tips
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
Feb 04, 2011 | NAD T754 Receiver
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
Programming the remote
If you go to the SONY site and look under support, go to remotes. Dial in your devices model number nad you can download the manual and all the codes.
Jul 12, 2008 | Sony RM-V201 Remote Control
62 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
