Question about Canon Pixma MP800 All-In-One InkJet Printer
Adjusting lamp scanner - Canon Pixma MP800 All-In-One InkJet Printer
They are getting a warning on the light bulb\r\nSense Key=0x4 ASC=0x680 DDES=0x7E
Hi Dana,
The error you are receiving is Flatbed Optical Alarm.This alarm occurs when the READ command for the first document is received, or when gain of the CCD amplifier is adjusted (sheet guide is read) during scanning.Probable causes are:
- The lamp, optical system or white sheet guide is dirty
- Defective lamp, heater, CCD, or inverter
- Connector disconnected
  1. Does the same symptom occur after turning OFF and ON the scanner? Check the scanner.
  2. Is the White sheet guide (glass) in the FB cover dirty? Remove the FB cover and clean the White sheet guide (glass).
  3. Is the Optical unit dirty?Are cables damaged?Are the connectors connected properly?Check all.
  4. Do the Lamps FB light up?Are cables damaged? Are the connectors connected properly? Check if the lamps light up during the Paper feeding test.If not, the error is caused by the defective Lamp FB or Inverter.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 16, 2011 | Fujitsu fi-5750C Flatbed Scanner
When we make copies they come out really, really dark. We have the setting as light as it will go. How can we resolve this?
  • try this when a dark image of original.
  • clean the scanner cavity,lenses,mirrors,scaner lamp reflector
  • adjust/increase scaning lamp voltage (on lamp regulater pcb)
  • clean/adjust hight of charging corona wire
  • adjust bais voltage in servce mode (add function then both key2 and 8 saimantaniously then add funtion)
  • adjust/replace cleaning blade
  • replace scanner lamp
  • Try this when zed black copy came out
  • check scanner lamp is working
  • check developing unit connection and contacts
  • check drum earthing contact
Jan 06, 2011 | Canon NP 6230 Copier
Copier has and "L" and blinks back forth between
Hi this error may happen due to problem on the scanner unit. Please check the following;
  • Turn it off the on if it doesn't clear then
  • Check the scanner lock above paper exit tray and unlock it then off and on
  • Check that the copy lamp is lighting ,if not check the lamp cable and lamp itself and replace.
  • Check the scanner motor and the rail then pulleys and adjust.
Be careful while handling brittle glass.
Dec 10, 2010 | Sharp AL 1631 Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Kyocera c3200 error Problem
A C3200 is as follows:
Exposure Lamp Problem.
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Solution:
Defective scanner board (KP-5063).
Replace the scanner board (KP-5063) and check for correct operation
Defective exposure lamp or inverter board.
Replace the exposure lamp or inverter board.
Incorrect shading position.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Poor contact of the connector terminals.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
May 02, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
When trying to scan a document on my CanoScan 8000F, I got an error code that read: "Cannot scan for these reasons: ? The original may not be set correctly. ? The Film Adaptor Unit Protective Sheet may...
Check that the lamp is not burning out, or replace with new lamp. Check the glass area to make sure there isn't a thin plastic sheet on the glass. This should be removed. Let lamp warm up for about 5 minutes before using.
If your problem still persists, it's not your computer, but likely the scanner software inside the scanner itself.
Apr 17, 2010 | Computers & Internet
ERROR C 3200 . IS OCCURING WHILE TAKING PHOTO COPIES.PLEASE HELP US AND GUIDE US
clean saner then
if its not solve your problem check exposure lamp harness connections; adjust the position of contact glassshading plate or clean/replace the scanner home position sensor;replace the exposure lamp or inverter pcb if needed; replace scanner board or engine board
1. defective exposure lamp or inverter board
2. incorrect shading position
3. poor contact on connector terminals
4. defective scanner board or engine board
Mar 07, 2010 | Kyocera Office Equipment & Supplies
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
Adjusting the lamp
Hi,  This is normal for the 4200F and it's just the time taken to warm the scanning lamp up. Once it's warmed up it shouldn't need to go through the process again for any additional scans, unless it's had long enough to cool down again of course.
I've noticed from another answer to an earlier question that if it's a big problem you can change the following keys in your registry:
HKEY_CURRENT_USER\Software\Canon\ScanGear\8.6\Devices\CNQ4200
 Energy save changed to 1
 Lamp Off Time changed to 0
Looks like this would prevent your lamp switching off at all unless you unplugged your scanner which would undoubtedtly shorten your bulb life. It may be a better idea to play about with the 'lamp off' key number until it just stays on long enough to not cause you problem.
Cheers, Derek
Dec 24, 2008 | Canon CanoScan 4200F Flatbed Scanner
Canon Pixma MP800 All-In-One InkJet Printer Logo
20 people viewed this question
old marine
old marine
