Question about Measuring Tools & Sensors
Shindaiwa problems hard to start
2 Suggested Answers
  • 64 Answers
SOURCE: Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
Posted on May 04, 2010
My Shindaiwa T230 grass trimmer want start sometime when i cut it off why?
yes --fire away
include make , model and as an accurate description of the problem as possible
Apr 08, 2018 | Weedeater Garden
I have a Shindaiwa weed eater 22 t while I was using it I accidentally hit the off switch when I try to start it again it wouldn't start I pulled the spark plug out to check to see if it was firing I...
Pull plug clamp battery charger jumper cable to body of plug other end to cylinder body pull starter rope and observe plug for firing at tip, you may need to darken room as some sparks are hard to see especially in sunlight.
Oct 06, 2017 | Light Garden
Hi I have a shindaiwa s25p water pump it ran and worked well years ago when I last used it now I'm having trouble starting it a friend wastampering with thefuel mix screw?
have a diaphragm kit put in the carby as the diaphragms do not last
they go hard and will not seal and flutter to pump fuel
or clean out the carby and the jets , float and needle and seat
Sep 29, 2016 | Cars & Trucks
Shindaiwa eb802 hard to start
If it is not the fuel hose thats porous or bad tankairiation it will be also not the spark color red gaskets or ??? , remove the muffler and look at your piston side Look through the outlet port that it will have no grooves because you have lost compression on the piston by or a bad cooling to high rpm's and or bad fuel mix or (L + H) adjustment of the carburetor if there are grooves on the exhaust side
This is an little suggestion made by repair an other brand but it make no difference
Husqvarna husky 240 chainsaw Piston Cylinder Inspection
Mar 13, 2016 | Garden
I need a carb kit installation guide for my Shindaiwa n452 hedge trimmer
There is no guide. Post the model and manufacturer of te carburetor itself. Walbro, zama, tk, etc.
Sep 20, 2013 | Shindaiwa N452
Shindaiwa trimmer carburetor adjustments
contact shindaiwa direct on web and make this request on them
Jun 09, 2013 | Garden
Do you use 2 cycle or 4cycle oil for mix in shindawai blowers
Not knowing what model blower you have, I do know that Shindaiwa manufactured both two cycle and 4 cycle blowers. In either case, you run the required 50:1 ratio. I would also recommend using the Shindaiwa branded oil since it is formulated to run in their equipment at that ratio.
Other manufacturers have 4 stroke blowers on the market that run "straight" fuel because they have an oil sump for the engine oil, much like a 4 stroke lawnmower. However, that is not the case with Shindaiwa's 4 cycle design which still runs "mixed" fuel.
Feb 20, 2011 | Echo Back Pack Blower Rack Fits Stihl...
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Craftsman weedeater wont start
The problem that I had with my craftsman was that I found that there was a tube in the fuel tank that goes to the carb, & at the other end - inside the tank, there was a small screen with maybe a weight on it (to keep it in the gas no matter what position the weedeater is in). Mine was plugged up and i went to the saw shop and got a generic hose & end with the screen deal & changed them out. Solved my problem. Rick
Mar 24, 2009 | Poulan Genuine Weedeater Part # 36006-128
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
