Question about Mitsubishi VS-5047 50" Rear Projection Television
Convergence Problem I have a Mitsubishi VS-5047 and when I try to adjust the convergence, the red lines will adjust and line up fine, but the blue cross lines will not respond. In the convergence adjustment, it allows for 5 different adjustments: the center and each corner. The center blue cross is aligned just to the right of where it should be, but in the corners, the blue will stretch to the corner of the screen outward from the cross that it needs to align to, and it is bad in every corner. can this be adjusted manually by loosening or tightening screws, or is there something that needs to be replaced?
  • allen8r84 May 21, 2009
    do you know where I can get those parts for this particular model?
  • 6,784 Answers
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
Posted on May 21, 2009
  • Michael Masters
    Michael Masters May 21, 2009
    Sure, just click this link below and it will direct you to a purchasing page for the part you need to replace.\
    CLICK HERE
Convergence
Posted on Jun 08, 2011
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence problem
YES YOU CAN DO IT MANUALLY WITH THE SCR,IF IT WERE ME ID TRY DOING IT.THE FRONT SPEAKER GRILL COMES OFF,YOU CAN GO FROM THEREEWS,BUT YOU MAY SCREW IT UP MORE THAN BEFORE
May 21, 2009 | Mitsubishi VS-45609 TV
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
204 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
