Question about GE Monogram® ZISS420DMSS Side by Side Refrigerator
No water goes to the ice maker but drinking water works ok
SOURCE: GE PROFILE PSS26msrd Ice maker
if the water dispenser is working normally and ice is not producing, take thr water filter out rinse it with hot water and put it back, this is the important thing to do after you put the water filter back you must hold the water filter reset button at least 3 seconds to reset the system and it should working fine.
Posted on Jan 23, 2009
SOURCE: Ice Maker Problem
sometimes the ice maker works and sometimes it does not work.
Posted on Mar 09, 2009
  • 531 Answers
SOURCE: drinking water has stopped flowing in the door
look in the refrigerator take the buttom bin out check the back wall you will see the water line if not frozen press for water and hear if the water valve come on
Posted on Apr 06, 2009
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
  • 7 Answers
SOURCE: Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Posted on May 15, 2009
The ice maker on my Kitchenaid KBF320EVMS4 french door refrigerator stopped working. The drinking water works fine and I can hear the noise when the ice maker fills with water but no water comes in.
you can pop the cover off of the ice maker,on the module you'll see some letters,if you get a jumper wire and stick it into the T and H the ice maker should start to spin,if it doesn't the ice maker is bad,then remove the wire and stick it into the V and L,water should start to fill the ice maker,if it doesn't most likely you have a bad water valve,just get a piece of wire,strip off both ends to make a jumper wire.one more thing,check the fill cup and the fill line to see if there's any ice in there,if the water valve is bad water can drip through and freeze in the cup or fill line stopping the water from entering the ice maker,if there is melt it out with a hair dryer,also if you have to get in there with a hair dryer be careful with the heat on any plastic parts,you can damage it and don't heat the fuse on the ice maker wires,it's a black fuse built into the harness you can damage it if it gets to hot.you can go here to see your parts
https://www.searspartsdirect.com/model-number/KBFS20EVMS4/0593/0161000.html?searchType=modelSearch&q=KBF320EVMS4&searchTerm=KBF320EVMS4
Nov 22, 2017 | KitchenAid Refrigerators
WATER IS FILLING UP ONLY 2 OR 3 SLOTS IN ICE MOLD. HOW DO I DETERMINE WHY WATER IS NOT FILLING UP ALL UNITS IN ICE MOLD TRAY?
Possible restriction in the water fill line to the ice maker. Possible ice build up in line.
Oct 07, 2014 | Refrigerators
Ice maker not working,drinking water part is,do not see any water in ice tray
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 15, 2010 | Frigidaire FRS26R4A Side by Side...
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
The ice maker works, I poored water directly to the ice maker and it works, don't understand what you mean with alligator clips, should i just take the hose leading to ice maker off, the intake water valve...
Wrong! ok what it is you have a double water valve. 1 valve goes to the ice maker and one goes to the water dispensor. what you need to do is take the valve that goes to the ice maker by tracing the water line from ice maker to the valve and jump it direct with 110 volts. if you get water by doing that the ice maker is bad if you dont get no water that way it will be the water valve
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker will not make ice
I have the same problem. here is what is happing in the frezzer I have to unplug it let it defrost and I take the back wall apart and the fan and all back there is frozen I put hot water on the frozen parts and then it is good for about 6 mos before I have to do it again. My Daughter has the same problem also the water tube that goes to the ice maker frezzes and untill I get the cube of ice out it will not make ice. make sure you have the drew that holds the ice all the way in.
Dec 21, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Open Questions:
See all GE Monogram® ZISS420DMSS Side by Side Questions
GE Monogram® ZISS420DMSS Side by Side Refrigerator Logo
14 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
