Instructions rcl 3000 lantern
I cannot get the lantern to light up even though the battery has been charged on the lantern and the battery changed in the remote. the charge lights show both are charged
2 Suggested Answers
gopakumarg43
  • 74377 Answers
SOURCE: RCL 3000 remote controlled lantern appears charged but the lights will only flicker when you pull the charger in and out as if there is a short or something
Check its battery. It might be weak. Replace it and check.
Posted on Nov 06, 2012
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
