Question about Sony STR-DN1030 A/V Receiver Receivers
The STR-DN1030 receiver will not power on, I get the green light for a few seconds then back to orange standby
When I turn the receiver on the standby button will be green for a few seconds then go back to orange, will not power on. It stopped working in the middle of being used. the unit was very hot so I left it off for a few hours and now will not power back on.
4 Suggested Answers
  • 4234 Answers
SOURCE: STR-DH700 won't power up unless I unplug-plug it.
This is a logic problem with the internal microprocessor. A quick experiment: Turn the unit on for about 2 minutes and shut it down. Doe sit power uip in this case? If so, I'd suspect that the heat generated during normal operation is creating an internal problem thaty is preventing the micro from recognizing the "off" condition. The power data line is hung and is not being recognizwed by the micro so any attempt to turn the unit on will fail. The unplug/re-plug essentially clears or resets the unit.
If the unit is new, return it for warranty repair. It will be important to describe when the unit fails however. Try to see how long it must remain on for the problem to occur.
Update this with your results if the unit is not under warranty and we'll try to narrow it down.
Thanks,
Dan
Posted on Nov 05, 2009
Zacnickp
  • 33 Answers
SOURCE: sony str d-1015 stereo receiver stopped working
if you have been blasting it, that could be why, recievers of this era are made with cheaper parts that cant handle what theyre supposed too,
i dont know specifically, but things like that have some sort of auto fuse...
i would assume, you are using it with wrong ohmage speakers, are you using car speakers? car subs? older speakers?
most home stereo equipment is 8 ohms, i have a set of 140 watt 3 way (10"[vented]/4"/2") as fronts and a set of 80 watt rears (6"[vented]/1.5"/24mm) the fronts are induviduals, meaning they have to be bought individually, and are not sold as a set, or part of anything, the rears were part of a bookshelf system, i got the set secondhand... but i always checked the ohmage...
Posted on Jan 08, 2010
supertech6
  • 513 Answers
SOURCE: powers up, all lights buttons seem to work, but no sound
This can happen. Lightening causes static charge that can be picked up by speaker wires. It is possible ONE of the amplifiers has failed.
To check, have the room quiet. Turn on the amp. After 5 to 10 seconds there should be a nice solid 'CLICK' from inside the amp. If there is no click, the unit is in safety mode. You will need a service shop.
Posted on Apr 17, 2010
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Same Problem As Well
microcontroller needs to be changed
Jul 07, 2009 | Harman Kardon AVR 7300 Receiver
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Yellow light
Yes this is perfectly normal, the colours are as follows with meaning: Red: Completely off, no wifi connectivity, Yellow/orange: Standby, Wifi connection on (enables you to receive messages) Green: On
If you want the console to completly turn off just hold down the power button for a few seconds rather than just pressing it.
Apr 11, 2009 | Nintendo Wii Console
Sony STR-DE315 will not power up
Do you have its service manual to go further in unit? let me know as schematic is necessary to rectify its problem of no power.
Regards,
Sep 10, 2008 | Sony STR-DE315 Receiver
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Sony STR-DN1030 A/V Receiver Receivers Logo
183 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
