Question about Bose CineMate GS Series II Speaker System
Red light doer not come up on the cinemate 2 interface module
SOURCE: Bose Cinemate Home Theater
same prob, the tech was no help wants me to send in 75 bucks and pay for the shipping
Posted on Apr 28, 2008
  • 53 Answers
SOURCE: interface module and/or bass module power problem
Eric,
Take their offer Bose is not that forgiving.
Send it back let them deal with it.
If you try to DIY it you'll void warrenty and will be totally SOL
Good luck
Posted on Jun 24, 2008
  • 6 Answers
SOURCE: When I plug in my cinemate system the green light
probablemente no este ccodificado el control remoto asegurate de poner pilas nuevas y trata otra vez checa los cables que van al modulo interfaz ya que pueden estar quebrados o sustituyelos o bien el sistema de interfaz no funciona o llevalo al centro de reparacion bose
Posted on May 02, 2010
charlestrep9
  • 15 Answers
SOURCE: I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Posted on Oct 20, 2012
SOURCE: replacement part for Bose Cinemate Interface
Radio Shack has the part for under $5.
Posted on Nov 08, 2012
The light on the interface will not come on
Try powering the unit down for 30 seconds and then power it back up.If after pluging and unpluging you still have the fix red led then the IR Detector Module inside the CineMate Interface Module is not working. You have to replace it. The Part Number is 1B83 41A. You can but this part at Radio shack for under $5.00 , remove the old one and solder a new one in, 3 leads of the LED. This was the way I fixed mine
Mar 23, 2014 | Bose Cinemate Digital Home Theater System...
Bose cinemate troubleshooting
If the light on your control console just stays red and never changes, then the control module is probably bad. It's pretty common on the cinemate models.
Jun 06, 2013 | Audio Players & Recorders
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
When I plug in my cinemate system the green light on the interface module won't turn on and power up. It only stays red and doesn't respond to the remote. I have unplugged and reset the system and check...
Apr 21, 2010 | Bose Cinemate Digital Home Theater System...
Same problem. Bose CineMate light went red and doesn't come back green even if I tried changing batteries and doing 5 step approach mentioned above.
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Jun 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Interface module and/or bass module power problem
Eric,
Good luck
May 12, 2008 | Bose Cinemate Digital Home Theater System...
Interface Module
just unplug all the speaker cables and then see if it switches on if it does one of your cables or speakers, i hope that can help you:)
Dec 22, 2007 | Bose Cinemate Digital Home Theater System...
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
Bose CineMate GS Series II Speaker System Logo
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
