Question about Pioneer DEH-245 CD Changer
PLAYER WILL NOT TURN ON AT ALL
I CHECKED ALL FUSES IN THE FUSE BOX, I WANT KNOW IF THERE IS A FUSE BEHIND THE PLAYER, AND I WENT TO MOVE ANTENNA AND IT TOUCHED SOME BARE METAL AND SPARKED
I NEVER HEARD ANTENNA BEING HOT, I HOPE I DID BURN THE PLAYER UP, THATS WHY I NEED A MANUAL AND WIRING MANUAL FOR A PIONEER DEH-245 HIGH POWER 35W X 4 UNIT
    Problem Solver:
  • 18 Answers
I bet it is just dirty try putting it in the dishwasher for a complete cycle (with dry).
Posted on Jul 01, 2010
    Scholar:
  • 105 Answers
There is a fuse on the back of he player usually right above where you attach the wiring harness.
Posted on May 22, 2009
No power to fuse box under dash. 94 lincoln town car
Better take the dash back apart , you didn't connect something , something came apart . Your answer is behind the dash .
Jan 24, 2017 | Lincoln Town Car Cars & Trucks
Turn signals inop
Your flasher may have went bad. It usualy is round and silver. Or your fuse /relay is bad.check under hood on top of fender for a black box with fuses and relays in it . Look for turn signal or flasher fuse/relay on underside of box lid. Or look in the owners manual. Should also be fuses inside on drivrrs side undrr dash or passenger side behind glove box.
Jun 04, 2014 | 2001 Toyota 4Runner
Driverside seat wont move ,stuck in farthest back position
The fuses for the seat are shared with other features on the car such as power antenna. Has any other power feature gone off as well?
Check the runners the seat slides in. There might be something trapped in there blocking the running action.
There are two fuse boxes. One under the hood in the rear drivers side corner, under a black plastic cover. The other is inside the car, inside the end panel of the dash. (With the door open).
Check fuses 1 and 18 as they cover the power seat functions.
https://autobonches.com/amp/fuse-box/2003-ford-explorer-fuse-box-diagram/
Jan 15, 2018 | 2003 Ford Explorer
What fuse is for the cigarette lighter on a 2008 ultra
Hi Anonymous, traditionaly it was the accessory fuse, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Feb 12, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
2003 Suzuki VL 800 speedo cluster, signals, brake light won't work. Worked on the way to work this A.M. Checked the two fuses under seat. ?
Did you also check the system fuses? The fuse box is located behind the left side crankcase cover above the coolant reservior.
The 15 amp Signal fuse protects the coolant temperature light, the turn signal indicator light, the neutral indicator light, the oil pressure light, horn, brake/taillight, postition light and turn signal light. Basically, if this fuse is blown, your cluster will be inop.
Please let me know if this is helpful.
Jul 21, 2010 | 2002 Suzuki VL 800 Volusia
Half of electrics stopped working but yet the fuses are okay
Time to do a wiggle test of the fuse box wiring. The circuits mentioned are not directly connected , but may travel through common wiring plugs. Try the fuse box fuses again (there may be more than 1 fusebox) Interior light / Radio / Antenna / Clock may be on a battery circuit but not connected to the Fog light not the turn signals other than a connecctor plug or simular.
Mar 17, 2010 | 1997 Volvo 960
2000 bmw x5 nav screen blank. radio works but no
I know this is an old thread, but my 2006 325i Nav screen went bank also, but the radio still played. I noticed the glove box light and trunk light did not turn on also. I was told from mechanics is was probably a CID module for $2200, even though I mentioned the glove box and trunk light light were out and specifically inquired about a fuse. The mechanics never checked the fuses, because I checked my fuses in the glove box and found the fuse 61 marked with a BMW symbol that looks like light bulb was blown. The Nav screen started back up once the fuse was changed.
Feb 03, 2010 | 2000 BMW 5 Series
2003 ford escape. radio and sideview mirrors don't work, but clock in radio does. I checked both panel of fuses.
for radio
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna or antenna cable
  • audio speakers mounting/speaker cones
  • Radio ignition interference capacitor, radio frequency interference suppression bond
  • Central junction box (CJB) fuses:
    • 19 (10A)
    • 12 (5A)
  • Battery junction box (BJB) fuses:
    • 19 (40A)
    • 20 (40A)
    • 27 (10A)
  • Connectors
  • Ignition switch
  • Circuitry
  • Audio unit
for mirrors
  • Exterior rear view mirror(s)
  • Interior rear view mirror
  • Central junction box (CJB) Fuse(s):
    • 8 (10A)
    • 16 (10A)
  • Circuitry
  • Exterior rear view mirror motor(s)
  • Exterior mirror control switch
  • Heated rear window switch
Jun 28, 2009 | 2004 Ford Escape
Wiring issues
Check now the fuses in under the hood.
Vitally
May 05, 2009 | 1995 Honda Accord
Pioneer DEH-245 CD Changer Logo
279 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
