Question about Dryers
One of the 3 tumblers inside the dryer fell off.
Somehow the screws came un done. I think all I have to do is open the front, find the screws and screw it back in. I don't know how to open the front though and I'm not sure if that is the best way to fix the problem. Thanks for your help. the dryer tumblers fell off of my kenmore he front loader any help would be appreciated.
  • 245 Answers
You actually open the top first if you look between the front and the top you will see two clips. push these in with a small screwdriver to lift the top. then there is two screws holding on the front to get it off.
Posted on May 21, 2009
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How to repair paddle inside drum paddle that fell off
To replace this "paddle" (It's callde a baffle), you'll need to access the outside of the tumbler (drum), by lifting the top.
Begin by removing the door. Remove the two hinge screws. You will then be able to rock the door and hinge out of the slot in the front panel. Next, remove the cover plates just opposite the hinges.
Now you can pull the front panel off the retaining clips and rock it downward, away from the rest of the cabinet. Once it clears the top, you can lift it off the bottom hooks. Just set it aside.
You will now see two screws (hex-head, 5/16 inch), just under the corners of the dryer top. Remove them and rotate the brackets that hook into the top. Removing the brackets will allow you to now swing the top upwards to expose the tumbler.
Just turn the tumbler until you can see the screw holes for the babble holding screws. You may get lucky and find the three baffle screws in the bottom of the cabinet. Re-install, check the others, and re-assemble the dryer in reverse order, and you're done!
Dec 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Tumbler belt came off
  • Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
  • Oct 11, 2010 | Whirlpool Dryers
    One of the paddles in the dryer tumbler fell off. How hard is it to open the lid and screw them back on?
    Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
    The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
    Swing the bracket to the outside and unhook it from the slot in the top cover lip.
    Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffle securing screws can now be re-tightened or reinstalled. Reinstall the top cover and the front panel by following the removal steps in reverse order.
    Oct 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing...
    Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
    Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
    Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
    Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowest outside screw at each corner then the top screw on each side.
    Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
    Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then grasp the idler puller with your left hand and pull the idler upward and to the left.
    Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
    Place the belt onto the outside of the tumbler and position it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
    Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
    Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
    Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
    Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
    Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
    Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
    Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
    Aug 22, 2010 | Dryers
    I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
    Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
    You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
    You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
    Good luck.
    Regards,
    May 15, 2009 | Kenmore Dryers
    either the top pries up and you'll have 2 screws on the inside front panel or you'll have 2 screws at the very bottom of the front panel those are the 2 basic ways of opening your dryer
    Mar 11, 2009 | Maytag Dryers
    Fins fell off tumbler on Whirlpool Ultimate II dryer
    Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
    Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
    Job done.
    Plz rate this soution.Thanks.
    Jan 01, 2009 | Whirlpool Dryers
    Put belt on dryerg
    While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
    1. Unplug the dryer or disconnect power.
    2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
    3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
    4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
    5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
    6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
    7. Reconnect the wires to the door switch, if you removed them earlier.
    8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
    9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
    10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
    11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
    12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
    Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
    Dryers Logo
    56 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
