Question about Danby Freezers
Freezer not working - Danby Freezers
We have an E388 upright freezer...motor is still running but fan inside freezer has stopped working and freezer does not freeze..Any reason ?
dear sir/madam
i think your freezer,s indside motor is faulty so its not rotating motor is not working so freezer ,s evorator cycle is not having complete its reson for not cooling .
please contect to your freezer maintenance personnel for further action
hope answer the question
thank you.
please vote!
Jul 15, 2010 | Fisher Freezers
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Freezer just stopped working
  1. You need to unthaw the freezer, and it should start working.
Sep 11, 2009 | Freezers
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Kenmore upright freezer. left and right outside box sides are fairly warm. Is this common?
yes. This is the way freezers work. Every freezer will do this. If the freezer doesnt do this it generally does not work properly. So to answer your question... its nothing to worry about.
Jul 01, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
