I have a base 7" portable dvd player. i put the disc in correctly and it keeps coming up "wrong disc". have read the manual that came with it and all it says is that the disc may be damaged. so i have tried 12 different dvd's and it keeps coming up with "wrong disc". What do i do? please help!!!!
  • 854 Answers
These products are fragile and prone to failures of many kinds due their internal complexity.
If it is still under warranty you should have it repaired by their authorized facility.
It may reset and start working again. Unplug the power adapter and remove the batteries for a period of at least 30 minutes; then try it again.
If the reset does not help it means there is a mechanical or electronic failure. There are many possibilities and it is impossible to know without doing some testing of the unit by skilled hands. The usual or most common problem when these symptoms occur is a weak or dead laser diode (which is mounted inside the optical pickup assembly). Since the laseer cannot read the data on the disc the servo mechanism thinks there is no disk in the unit and shuts down the drive motor.
Replacing the laser diode is very expensive and it requires the entire optical pickup to be replaced and realigned. And, you may have to wait several days for the replacement parts and repair. It is NOT something you can do at home.
Posted on May 21, 2009
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Portable dvd player keeps saying bad disc
try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Nov 27, 2008 | Televison & Video
Wrong disc
Laser lens may be dirty, try gently cleaning it with a cotton bud with a tiny drip of vodka on the end, i mean the tiniest bit. The lens is the small round, domed clear plastic thing in the player under the lid...if it is top loading. Are playing retail DVD's or any sort of disc you have created on a PC. A lot of players dont like RW-DVD disc's.
Nov 06, 2008 | NextBase SDV-17 Portable DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
Porttable dvd player
If the manual have not come up with anything to fix that problem, you may want to try a CD/DVD laser cleaner for it.
If you still have problems, please contact the following website:
www.cobyusa.com
If you the website does not give you solutions, you may want to take this product to a customer service representative or something.
Mar 02, 2008 | Coby TF-DVD7005 Portable DVD Player
Problem
I have also had the misfortune of owning one of these substandard pieces of trash. I corrected my wrong disc error by manually moving the laser towards the center. The laser seems to jump off track and gets stuck on the outer edge for some reason. I'm still battling a software issue that keeps reverting to the set-up screen.
Oct 12, 2007 | Coby TF-DVD7005 Portable DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
