Question about Tools & Hardware - Others
Bit slips out even with collett tight
Problem started recently
Even when collett is tight the bits slip out making ever deepening cuts
Could collet be worn out? Router gets very heavy use.
  • 1,889 Answers
Yes the collet jaws are worn out replace them
Posted on May 21, 2009
    President:
  • 1,902 Answers
That would be the only thing to cause this type of a problem. I had the same problem replaced the part and away I went like nothing ever happened
  • 4 Answers
It could well be, but not necessarily the jaws, Most routers have a double tighten system and quite often ( have done it myself when youngster) an inexperienced person will feel the first tighten up and think all's fine. Another reason is trying to take too deep of a cut causing too much vibration and release of cutter. Always allow the machine to do the work which can mean 2, 3, 4 passes, this will give you a much better cut and less sanding, reduce any burning to timber or cutter and help to prolong the life of the cutter, machine and operator.
Cheers Capt Mark
Posted on Jun 15, 2014
Router base depth won't hold
I feel your pain! This is not uncommon. If the bit is slipping out of the collet, it is probably due to a dull bit. The 1/4 inch shanks are more prone to this than the 1/2 inch ones, which is why most new routers use 1/2 inch. (Think about the large size as being analogous to a larger wrench being able to exert a greater torque.) However, if the problem is the housing slipping on the base, you can try wedging a little piece of sandpaper under clamp. If the clamp has a thumbscrew, use a wrench on it to tighten it just a bit more than you could possibly do it with strong fingers. It was just this problem that inspired me to ditch my old Craftsman for a Porter Cable. Good luck!
Nov 05, 2012 | Tools & Hardware - Others
My porter 1/4" router
Have you tried taking out the collet and cleaning it and the cavity where it goes? If there is any wood dust present it may be causing the problem. If that doesn't fix it, you may need a new collet.
Sep 06, 2011 | Porter Cable 690LR Router
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
I have problem with my collet in my router. As soon as I tread the nut on the collet squeezes to the point I can't get a bit in. If I put the bit in the collet then try to tread the nut on it will not...
Never tighten a router collet empty. This will bend the collet smaller and it will be too tight.
Simply replace the collet. Call the Mfg the collet may be off specs a few thousands of an inch.
When not using the router store the nut loose on the threads enough it doesnt fall off.
Feb 19, 2011 | Freud FT2000E 3 Router
The sleve that holds a 1/4" bit came out and will
That's called a 'collet'. Sometimes you have to squeeze a collet to get it to go where you need to, but look both the 1/2" and 1/4" collets over carefully for a burr or flat spot that is causing them to not go together first.
If you see a spot that's keeping them from going together, work it on a fine oilstone. Any little irregularity can keep a collet chuck from gripping the tool well, so you want to be sure that there is no damage to them, also that there is no sawdust or sawdust residue in either collet. Once a collet tightens unevenly the tool will slip and you'll have trouble with it forever.
Once all is well, just get your little pair of Vise Grips and give it a gentle squeeze and it should slip right in.
If that doesn't do it, get back to me on the 'comments' tab and we'll go from there.
lp
Jan 11, 2011 | Makita & Plunge Router
Can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
Jul 31, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
My router will no longer grip the bit
you just need to replace the collet, should be able to find one online easy enough,
oh, and make sure there isn't any rust inside the collet, that could make it slip
Jan 24, 2010 | Makita 1 hp Router 3606
I am unable to get a tight fit on my router bit.
could be a couple things. First how is the shank on the bit e.g. is it worn down, second is it the right size for the collet being used (have to ask) and what is the condition of the collet and collet nut. What I would do is make sure there is nothing to prevent from completely tightening the collet nut. Also make sure if the collet locks into the nut that it is properly installed. Lastly make sure that you use the wrenches provided to tighten the assembly. If this doesn't help please provide the model number and brand and I will do some more research.
Jan 02, 2009 | Milwaukee 5615 21 Factory Reconditioned 1...
Slipping Bits
Any time I have ever come across this problem over the years the cause of it is a damaged collet due to overtightening. The solution is to replace the cone shaped piece ( the collet ) and take care not to overtighten in the future.
Sep 16, 2008 | Porter Cable 1 - 3/4" Hpfb Router with...
Tools & Hardware - Others Logo
187 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
