Question about Sony DVP-NC85H Multi-disc DVD Player
Progressive scan problem - Sony DVP-NC85H Multi-disc DVD Player
When i try using prgressive scan it comes up error why and how can i get progressive scan to work
In order to use progressive scan you must have a progressive scan compatible tv. Check your users manual to find out if its compatible. If it is it should give instructions to turn on the progressive scan option for tv.
Aug 26, 2011 | Zenith XBV442 DVD Player/VCR
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
Does the JVC xv s40 have progressive scan?
Sorry but this DVD does not have progressive scan. Before buying another DVD player with progressive scan ensure the tv you have can receive progressive scan signals. If not it doesn't matter if the dvd has progressive scan or not. Hope this helps.
Mar 08, 2010 | JVC XV-S40 DVD Player
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Progressive scan
To turn off Progressive Scan, press and hold the DVD Play button for 5 secs until the Progressive Scan indicator light goes off.
Jul 28, 2008 | Sanyo DVW-7200 DVD/VCR
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Jan 07, 2008 | Televison & Video
Sony DVP-NC85H Multi-disc DVD Player Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
