Question about Acer Aspire 3000 Notebook
Won't go past window xp logo
My acer asprie 3000 won't boot up all the way, gets to the windows xp logo and just keeps running. Then when you turn it off it goes into the mode where it asks you to start in the last know successful mode or safe mode but then when you hit that it just brings up a bunch of writting about drivers etc.
  • jacquelinel1 May 21, 2009
    I can't get even into safe mode to do any of the suggested things. It won't boot from the recovery cd either
  • 91 Answers
You will need to launch Windows XP Recovery Console..here are your to options you have to perform this to correct your boot issue..
Option 1: If you have already installed the Recovery Console loadTOCNode(2, 'moreinformation'); If you have already installed the Recovery Console, you can select it during your usual Windows Startup. To run the Recovery Console:
  1. During Startup, select Recovery Console from the startup options menu.
  2. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  3. When you are prompted, type the Administrator password.
  4. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  5. At any time, you can type Help for a list of available commands.
  6. At any time, you can type Help commandname for help on a specific command.For example, you can type help attrib to display the help on the attributes command.
  7. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
won't go past window xp logo - uparrow.gifBack to the top Option 2: Starting the Windows Recovery Console from the Windows XP CD-ROM loadTOCNode(2, 'moreinformation'); If you have not preinstalled the Windows Recovery Console, you can start the computer and use the Recovery Console directly from your original Windows XP installation disc. If your computer is already in Windows and you want to add the Windows Recovery Console as a startup option, go to the next section "Adding the Windows Recovery Console as a startup option."
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
Posted on May 21, 2009
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
To repair corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Jun 16, 2012 | Acer Aspire 3000 Notebook
How to skip logo and long boot sequence
That is booting directly into XP. The Windows XP logo that you stare at for a few minutes is actually hiding a whole lot of back end system checks. Without the logo you would be looking at a blank screen. There is a difference in load time, but it's about 2 seconds.
May 17, 2012 | Acer Aspire M1641-U1521A PC Desktop
Can't boot up Acer 1641 WLMi. Sometimes I get the Acer logo on screen, other times screen is completely dark. When the Acer logo does come on, I see F2 option listed on bottom of screen but it doesn't...
Hold the f2 key down and keep it down... It will bring you to the bios which will allow you to boot in safe-mode or by using rescue cd or partition in your hard drive. Your hard drive may have problems or has crashed.
Oct 03, 2017 | Acer Aspire 1641WLMi Notebook
I got it from a friend and when i power it up it will boot to thw windows xp logo but i get the blue scren of death and it restarts. i go into the bois to run a winpe disk and it finds no problems
The BSOD error would have helped in the diagnostic. In all probabilities a driver is corrupted. Boot in Safe Mode and uninstall all of them. Reboot normally , if the BSOD appears again then the problem is in one of the default ones and this time only a Repair install will fix it.
Jun 17, 2010 | Acer Aspire 3000 Notebook
My Acer Aspire 1 gets stuck when the Windows XP logo apears and just keeps booting, what can I do?
Hard Drive error on the Disk most likely... Try to go to Windows "Safe Mode"... pressing F5 before you see the XP Logo and after you see the system information screens. Once in safe mode... run ScanDisk.
Open My Computer | Right Click C Drive | Left Click Properties | Tools Tab Run Check Disk for Errors... also check mark both boxes.
Reboot
Jan 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Won't boot past Windows XP main screen. Windows XP may have a corrupt file. How do I correct without full recovery?
Try starting in Safe Mode and check if you can start it? In case it starts in Safe Mode, you may do the system restore to the date it was working fine.
Aug 11, 2009 | Acer Aspire 3000 Notebook
Install Xp on Acer Asprie 5735z
I'd reccomend backing up data and formatting your hard drive. Then install XP from disk and put data back on hard drive. You could use external hard drive or jumpdrive. It stands to reason that SATA works with XP, because the new computers I have seen have SATA and XP working conflict-free.
Feb 13, 2009 | Acer Computers & Internet
first go into device manager and write down exact names of drivers for
AUDIO
DISPLAY
NETWORK
SAVE ANY FILES TO FLASH/MEMORY stick
once you have done this let me know I'll tell you how to runxp
Jan 26, 2009 | Acer Aspire 5100 Notebook
NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
233 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
