Question about Atlas Lockjaw 2 Adjustable Poles
How to add powder baskets to Atlas LockJaw 2 Adjustable Poles
Just bought these poles but need to add the baskets.
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
Should I look for pole with removable basket option?
A removable basket is only a luxury. The removable basket option is convenient for flexibility as different types of baskets are available for different surfaces.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
Should I pick a fixed length or an adjustable pole?
Fixed-length poles are popular due to their light weight, but you need to be certain of the length you need before buying. Adjustable poles are slightly heavier and have the advantage of a choice of pole lengths while ascending or descending steep outdoor terrain.
What is a pole basket?
Trekking poles are usually outfitted with a small, removable trekking basket Baskets can be substituted for use in the snow or on soft, muddy ground.
What should I look for in wrist strap for my pole?
I just bought a Great Outdoors 9 by 13 foot screened gazebo from a local tag sale. Not surprisingly it came with no directions, and I'm lost. Where can I get instructions?
The company went out of business, so no chance at finding instructions.
BUT, there's a method to their madness.
Connect the #1 & #1b poles together to form 4x4' poles
Connect the #2 & #2a poles together to form 3x6'8" poles
Connect the #3 $ #3a & #4 poles together to form 4x6'5" poles
The shorter ones are for the 'Gable'... the canopy. The #2 poles are the cross-bars for the canopy, and the #3/4 poles are the legs.
Sep 01, 2012 | Garden
Ive got a 10x10 lawn and party gazebo made by summer rite ... do you know where to get instructions ?
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
_1430.jpgTake
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
May 30, 2011 | Camping, Backpacking & Hiking
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
Dec 23, 2010 | Sport & Outdoor - Others
I got the tent but no instrutions with it.
first lay it out on the ground put the pegs in 4 corners & centre then place the ropes and peg them into the ground about 3ft from tent then place the poles through the eyes of the tent erect the poles centre ones first stand the poles up then it should be upright from there just continue to add poles and ropes adjusting it during this procedure
hope this helps
Sep 13, 2010 | Computers & Internet
Replacement fabric basket
You will be able to buy the parts you want from www.buggypitstop.co.uk
Jan 01, 2010 | Mountain Buggy Urban Single Stroller
Atlas Lockjaw 2 Adjustable Poles Logo
740 people viewed this question
Top Atlas Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you an Atlas Winter Sport Expert? Answer questions, earn points and help others
