Question about Nintendo Skylanders Spyro’s Adventure Starter Pack Wii
Setting time on a kids watch - Nintendo Skylanders Spyro’s Adventure Starter Pack Wii
How can i set the time for a disney accutime watch LR626
Amazon.com: Customer Questions & Answers
www.amazon.com/ask/questions/asin/B00MA9D2XG
Amazon.com, Inc.Disney Kids' FZN3630 Frozen Anna and Elsa Watch With Graphic Band. by Disney ... Question: i have no directions for setting the time either in or on the pkg.Missing: accutime ‎lr626
Disney Kids' FZN3630 Frozen Anna and Elsa Watch With ...
www.amazon.com > Watches > Girls > Wrist Watches
Amazon.com, Inc.
Rating: 4.2 - ‎68 reviews
The digital time makes it easy for kid's to read. It light's up when you push it. The Frozen theme is adorable. This watch does not look cheap at all. It will adjust to ...
Dec 27, 2015 | Disney Watches
Do you know how do I get my watch out of military time?
change fro 24 hour setting to 12 hour settin
Nov 28, 2015 | Able Watches
Hd-56g647aa jvc tv theres a tv lock code kids got ahold of the tv remote but the lock comes up all the time and cant watch tv for longer then ten-fifteen minutes screen turns black and tv locks ive been...
Hi Anthony
Please try to go on the tv lock code features, may be you were able to set time. You just mention that 10 to 15 mints your tv will turn to black and then lock. You need to off the setting.
Jan 16, 2014 | Televison & Video
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
No volume on my Samsung 50" flat screen
Go check up the settings. First disconnect all appliances and then reconnect when power off. Configure connection when power on.
See your manual. You use the analog tuner or digital cable or satelte receiver to watch TV. If external digital decoder check your settings there. They are independend and might be low or muted sound level or incorrect setting.
Apr 14, 2009 | LG 42LC2D 42 in. LCD HDTV
Gap kids watch setting time
hit mode three times until TUES flashes and the seconds. Then hit reset to adjust which value you want to change, and then hit start to make the change scrolling through the hours and seconds
Jan 22, 2009 | Nike Triax Fly WK0006 009 Watch
Can't get kids gap watch move from military "24" hr time!
hit mode three times until TUES flashes and the seconds. Hit reset until the hours flash and hit start to change them. The watch goes from AM hours to PM and then back through AM and when it cycles through the PMs for the second time, they will alternate 12/24 hour time.
Dec 22, 2008 | Nike Triax Fly WK0006 009 Watch
Sportline watch setting time???
With the watch in time mode, press and hold the mode button for 4 to 5 seconds until it beeps and the digits start to blink. Then press the mode button again to advance through each setting. When finished press and hold the mode button to exit the setting mode.
Mar 15, 2008 | Sportline 1000 Memory watch
Nintendo Skylanders Spyro’s Adventure Starter Pack Wii Logo
193 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
