Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Does two 1ohm woofer = 2 ohm
I know how to drop a 2 ohm kicker to i ohm but i will get two, 2 ohm subs and i have a 3000x1 planet audio 1 ohm stable. if i drop the two kicker down to 1 ohm each will they add up too 2 ohm or remain i ohm even though it will be two subs at 1 ohm. if any one has any better suggestion help me i have yet to buy the subs...
  • Anonymous May 21, 2009
    but thats where i get stuck if i drop the the 4 ohm to 2 ohm how do i take the it to the amp to make it 1 ohm .. or will hooking the two 2ohm subs drop down to 1 ohm?
  • 245 Answers
If you buy the 4 ohm subs you can drop each of them to 2 ohm and then down to 1 ohm between the two of them. going with the 2 ohm no matter how you wire them you will either get 2 ohms 4 ohms or 8 ohms. hope this helps by the way the 4 ohm solobaric and the 2 ohm are both the same price.
Posted on May 21, 2009
    Scholar:
  • 111 Answers
Ok, I'm not sure where the 8 ohms came from, but you cannot make two DVC woofers equal 8 ohms. The problem is that you cannot get any lower than a 2 ohm load from the subs. You will only get a 1 ohm load from running two amps, one to each sub. Keep in mind, that's only IF you want to get that 1 ohm load. If you have a question or concern, here's the site for ya: http://kicker.com/dvc_wiring
Posted on May 18, 2010
Can Isubstitute a car sub woofer to my home theater systerm
Probably. Most Car Subs Are 4 ohms. Most home subs are 8 ohms. If your amplifier is 4 ohm stable then yes. There will be no problem. Your kicker could have a model number something like c104. The last digit should be the ohms.
Jan 23, 2017 | Kicker Car Audio & Video
Got 2 woofers, 2ohm stable each. If I get 1ohm stable monoblock amp, will it split that 1ohm equally in 2ohms for each speaker, or would I have to buy another 2 speakers that r 1ohm stable each?
Connecting the two 2 ohm speakers in parallel will create a 1 ohm load. Connect the positives of both speakers to the plus output of the amp, both negatives of the speakers to the minus output of the amp.
Sep 19, 2015 | Car Audio & Video
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
Wehen I turn the volume up my subs destort and it seems like my subs are bogging down..I have 2 kicker comp 12 vrs
if they are 4 ohm dual voice coil wire them to 1ohm and bump do not turn gain all the way you will fry the amp and if you really want to make them kick . write each 1 to 2 ohms and get another amp they are not getting enough wattage for the volume you are trying to run them at and could be the way you have it tuned .
Aug 06, 2010 | Planet Audio AP1000D Car Amp
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Planet audio vx3002
Sorry wayne2953 but this amplifier isn't stable @ 1ohm loads. This amplifier would be better suited running a pair of 12's, 4 12" subs could run if configured correctly but the subs would be underpowered and probably not sound very good.
Features of Planet Audio VX3002:
  • Max Power (2 Ohms) : 300W x 2
  • RMS Power (4 Ohms) : 150W x 2
  • Bridged Power (4 Ohms) : 600W x 1
  • Signal-to-Noise Ratio : 102dB
  • Frequency Response : 20Hz-20kHz
  • Dimensions : 10-5/8"W x 2-7/16"H x 16"L
Mar 31, 2008 | Planet Audio VX3002 Car Audio Amplifier
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
481 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
