Question about Coffee Makers & Espresso Machines
Delonghi magnifica coffee grinder overflows into ground coffee
2 Suggested Answers
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
Pre ground coffee
SORRY but FIXYA does not make coffee nor do we repair coffee makers . contact the manufacturer thru their website and ask tech support to assist
Oct 13, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Esclusivo Magnifica grinder cogs have stopped spinning while the hub turns, thus no grinding is done! Help
u need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Jan 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The grinder runs for to long causing overflow of ground coffee and wasted beans
pcb problem by the sound of it ... bsc appliances 07779933829 postal service too.
Jan 17, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
