Question about Gateway LX6200-01 Phenom X4 9500 8GB DDR2 750GB ATI Radeon HD 3200 IGP Windows Vista Home Pr... PC Desktop
Cant' open door for usb port
Can't open door for usb port
  • ikkenom May 11, 2010
    Can you turn off your computer, disconnect the power, and (for a laptop) remove the battery, and athen remove the side-panel(s) from your computer, in order to see the "back" of that door? If you can, try using a long screwdriver to "push" the back of the door, to see if it will open.
  • 696 Answers
Sorry, ikkenom, but this is one of the new FX/LX.DX series,
bonndini, Just push in on the top of the front usb panel, it will take more preasure than you think, then you will hear a click and when you let go it will open.
The top panel works the same way if you push down on it's front edge.
Hope this helps FixYa,
Chris
Posted on May 21, 2009
I even put it on the port where i initialized it,it still say cant open port
Hi, please follow the below steps:
  1. Make sure the device is plugged in to the correct USB port.
  2. Try to connect the device in different USB ports and check.
  3. Check with another computer if you have any.
  4. Check whether the device is compatible with the computer operating system.
  5. Make sure the device is getting enough power.
  6. Run fixit tool from the below link:
Diagnose and fix Windows USB problems automatically
Jul 11, 2015 | Computers & Internet
Usb ports
Sounds like something else is chewing up you memory have you got too much allocated somewhere else or control panel/ system /device manager/ serial bus controlers/ std open host controller... update driver, or uninstall and then reboot and windows should hunt it down for you. you may need the driver for it if it cant find it by itself, that means knowing what sort it is (motherboard handbook) and going to site and getting driver.
Dec 04, 2007 | Televison & Video
I cant update my ipod 3rd generation
Connect your iPod to the Dock Connector on the USB cable. Be sure you are using the Apple Dock Connector to USB port cable that came with your iPod.
  • If your computer has USB ports on the front and back, connect to a port on the back of the computer.
  • If iTunes does not recognize your iPod when you connect it, try closing and re-opening iTunes.
  • If it still does not recognize your iPod, restart your computer entirely and start over.[1]
update-ipod-3rd-generation-zqolyaycyhlhw3jfhb4adlfm-3-0.jpg update-ipod-3rd-generation-zqolyaycyhlhw3jfhb4adlfm-3-2.jpg update-ipod-3rd-generation-zqolyaycyhlhw3jfhb4adlfm-3-5.jpg update-ipod-3rd-generation-zqolyaycyhlhw3jfhb4adlfm-3-9.jpg
Mar 05, 2014 | Cell Phones
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
At first ti connect recognized devise now saying cant find my ti-89 device
At first, open TI Connect software and open TI Device Explorer. Then in the Actions menu choose option Select Device and select Port USB, Cable USB cable and Device TI 89 Titanium(all in the same line).
See captured images:
Feb 24, 2012 | Texas Instruments TI-89 Calculator
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
My laptop cannot recognize my usb port 6.1.7600.16385... i cant use it to upload my pics and download games from it, i also want to transer my files in the phone to my laptop..
first you must check in your bios settings have disabled your usb ports .if it is disabled in your bios ?? you must enabled it. if still have the same issue ?? check "device manager" option from control panel and enabled your usb ports.
open control panel -> administrator tool -> computer management -> device manager.
Sep 09, 2011 | Computers & Internet
I dumped everything off computer and still cant get futura ce100 to open did what singer said several times still won't open and machine is on. Please help running vista.
Make sure your USB cable is plugged into one of the USB ports on the BACK of your computer. The front ports or a USB hub doesn't have enough power to run the USB cable for the machine. Singer doesn't have enough computer knowledge to figure this out-this was finally solved for me by a PC expert at work after I went nuts for a few months! Hope this helps!
Jan 13, 2011 | Singer CE-100 Futura Computerized Sewing...
USB PORT
holding the camera with the display in front of you, on the left side there is a small door. open it, inside there is an entrance for the usb cable (the upper)
Jul 15, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Gateway LX6200-01 Phenom X4 9500 8GB DDR2 750GB ATI Radeon HD 3200 IGP Windows Vista Home Pr... PC Desktop Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
