Question about E-Machines eMachines Desktop PC
I want to clean the dust from my tower and blow canned air, but does the blue plug on cord pull straight out ?
I want to clean dust from tower does the blue plug on cord pull straight out? seams hard to do
    New Friend:
  • 38 Answers
Dear bonnie,
Years ago, on a computer tech help site, I read a posting warning against this unless a last resort? It said that if all was well - leave it be! as moving dust from where it has settled could possibly cause a 'short-circuit' & burn out components. Also do not know which cable is "blue plug on cord"? Make sure power is off at wall. The power plug pulls straight out from computer. Other plugs have obvious screws/screw-posts. If you are going to fiddle around inside your box, best practice is to wear an anti-static wrist band attached to metal screw/frame with power OFF at wall but leads still plugged in - (this will ensure that the computer is earthed & your body static - up to 50,000volts! - will not fry any components). I hope that this helps - kind regards - 'b'ye - Bruce.
Posted on Apr 28, 2014
3 Suggested Answers
cph770
  • 116 Answers
SOURCE: if i open tower to clean out dust will i get shocked??
It's not a problem, just make sure you pull the cord out of the plug.
You will not get shocked - anyway.
Posted on Oct 10, 2012
Testimonial: "this has eased my mind. when reading the how to,s i thought it said to ground my self!! or i would do damages to machine. thanks sooooo much!!"
  • 22 Answers
SOURCE: very simple question
Does it look like a VGA plug? http://en.wikipedia.org/wiki/VGA_connector
If so, you'll have to back out the screws on either side to take it out. Just do it with your fingers, or if they're too tight, use a flat screwdriver to do them (some even allow use of a phillips screwdriver). Just be careful as sometimes the screws want to take the screws that they're mounted in with them (they hold the VGA port in place).
If that isn't it, where is the plug and what shape is it?
Posted on Jan 02, 2014
Testimonial: "that was what i needed to know!! you have helped so much.i was scared to do that. thanks so much."
Tower fan stf-31s not blowing
The blades are probably covered in dust. Mine does this when it needs cleaning
Aug 06, 2016 | Tower Dryers
How do you clean a Crofton tower fan?
Any tower fan is something of a pain to dis-assemble. Lots of screws and tricky plastic parts that snap together in various ways. So I don't take anyting apart on the fan itself. I use an air compressor with a blower nozzle to get the job done. As you blow the fine stream of air over the vents and into various areas at the top and bottom, watch out for dust blowback. As you blow into the center vents/grille, the fan blade will spin around, too. After you've blown out the dust, use a damp rag, along with an old paint brush to clean out the grooves in the vents and grille.
Apr 25, 2015 | Tower Dryers
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
Very simple question
Jan 01, 2014 | E-Machines eMachines Desktop PC
If i open tower to clean out dust will i get shocked??
Oct 09, 2012 | E-Machines eMachines Desktop PC
I have a seville classics tower fan. How do I take it apart to clean it?
Good Luck!! I too have one and although I was able to take off a bottom panel and clean it- the important area (fan) proves quite inaccessable. I am very mechanically adept too. Either way felt it was a lot of trouble for nothing- so I used a powerful vacuum blower to blow out all the dust instead. When these fans can be purchased for 50 bucks, new, at Cost Co, it sort of eliminates the need to get real carried away with maintenance.
Nov 12, 2010 | Dryers
I need to clean both cooling fans on a sony vaio vgn cs215j/p laptop
if you just need to clean the dust from them, most stores that sell computers such as wal mart radio shack , best buy etc. sell cans of compressed air to blow out all the dust. just make sure your computer is turned off before you blow the dust out. i hope this helps!!!
Jan 14, 2010 | Sony VAIO VGN-CS215J/W Notebook
Fans on Mac Intel Tower
I would suspect it needs a good internal cleaning. The accumulated dust will cause the computer to overheat. Disconnect all cables and take the unit to a place where you can clean it. Remove the side panel and then with a can of compressed air or an air compressor blow all dust out of the unit. Pay special attention to the heat sink on the processor. Make sure you clean the power supply fan. Be sure and not touch any internal components without first grounding yourself to the chassis. It is best to do this outside as the dust will fly everywhere. You should clean the inside at least once a year. Merry Christmas.
Dec 15, 2009 | Intel Mac Pro Tower Desktop
Took cover off my tower and blew out the dust and when I hooked it all back up my monitor said no signal and light on my mouse just flashes
Lets tackle the monitor first: A no signal message indicates one of two things;
  • The video card isn't properly seated; (if the video card is on board skip to next step) just moving the video cable on the monitor to unplug it is enough to unseat the video card. Open the tower again and make sure the card is firmly in place.
  • If the video is onboard, the plug may not be firmly in place. Check the screws that hold the plug in place and see if they are turned as far as they will go; there's a chance the plug is only partially making contact giving you the no signal message
As far as the mouse goes, the only reason the machine won't recognize the mouse would be a faulty connection in the USB port. Assuming no damage was done while blowing the dust out, double check the USB port, maybe even changing ports to see if the mouse comes back. If your machine is anything like mine, space behind the tower can get kinda cramped and just putting it back into place and reconnecting the power cord can pull just enough on the lines to pull a line just enough to disrupt your connection.
Hope this answers your questions. Best of luck.
Greg
Jun 04, 2009 | ASUS P5S800-VM Motherboard
How to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Mar 22, 2009 | Dryers
E-Machines eMachines Desktop PC Logo
23 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
