Touchscreen 7335 not working - Office Equipment & Supplies
Why is there ghost printing/shadows on my xerox workcentre 7335?
Suresh,
You don't say if the ghost is a particular colour, by ghost I suspect you mean similar to a drop shadow.
Firstly run off an internal test print, one of each colour if the grid lines are fine and showing no signs of shadow then your problem is not an internal problem. Don't send a C,M,Y,K test print from your computer, you can't eliminate colours that way.
If you can pin the problem down to one colour it could be a particular drum unit. Investigate from there.
Good Luck.
May 03, 2015 | Xerox Workcentre 7335 All-in-one Laser...
I have a xerox workcentre 7335 with the blue registration not alined with the other colors I replaced the blue developer housing and set up the color registration but it didn't help what can I do next
The problem comes from the trensfer belt. There is a silver patch on the belt that synchronizes the colours. This is probably dirty or detached from the belt. You need to clean the patch or replace the belt
Sep 16, 2014 | Xerox Workcentre 7335 All-in-one Laser...
Xerox 7335 error code 010-391
Hi Anonymous,
Checkout the Fuser assembly.
Regards.
Jul 29, 2014 | Xerox Workcentre 7335 All-in-one Laser...
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
Centreware password on Xerox 7335
On mine it was the other way around username 11111 & Password x-admin
Jan 21, 2009 | Xerox DocuPrint 4517 Laser Printer
12 people viewed this question
jasbo
jasbo
